FLARM antenna installation
Old January 14th 07, 09:47 PM posted to rec.aviation.soaring
Kevin Neave
Default FLARM antenna installation
Hi,
I have recently imported a Discus BT into the UK.
The glider has FLARM fitted with the antenna mounted
under, and parallel to, the coaming.
The FLARM installation manual states that the antenna
should be mounted vertically.
Mounting the antenna vertically under the coaming means
feeding it down between the electrics, plumbing and
instruments behind the panel.
Ive considered mounting it on the shelf behind the
spars but that leaves it vulnerable to attack by any
other luggage on the shelf.
Anyone out there have any suggestions for mounting
the antenna wher it won't get blocked by the engine
/ fuel tank./ instruments / pilot etc.
Regards
Kevin
Old January 15th 07, 12:29 AM posted to rec.aviation.soaring
hans
For a picture of my installation have a look at
http://www.streckenflug.at/fotos/det...40&mode=search
A possible source for the extension cable for the antenna is
http://www.trautenberg.net/flarm_index.htm
Kevin Neave schrieb:
Hi,
Regards
Kevin
Old January 15th 07, 05:03 AM posted to rec.aviation.soaring
Andy[_1_]
Hans,
What are the 2 reels mounted on the left side just aft of the panel?
Andy
Old January 15th 07, 08:56 AM posted to rec.aviation.soaring
hans
The reels are for the rope of the bug wipers. But they are now removed,
as they hinder the bailout. I still have to find a solution for the bug
wiper reels.
Andy schrieb:
Old January 16th 07, 09:09 AM posted to rec.aviation.soaring
Kevin Neave
Hi Hans,
Thanks for the pictures, do you find the Antennas for
FLARM & GPS sticking up through the coaming to be a
distraction?
Kevin
Old January 16th 07, 07:53 PM posted to rec.aviation.soaring
hans
They are no distraction at all, as the Flarm antenna as well as the
large helix GPS antenna as the as the square GPS patch antenna are form
the pilots point of view behind the compass.
I have moved the GPS patch antennas now below the instrument cover.
Hi Hans,
distraction?
Kevin
I Hate Radios Ron Wanttaja Home Built 9 June 6th 05 06:39 PM
ELT antenna -- Pitts Al MacDonald Home Built 0 July 15th 04 04:27 PM
antenna installation in a glider? ken ward Soaring 5 May 19th 04 08:02 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 02:10 PM
LS-4 Transponder antenna location? Matt Herron Soaring 3 February 25th 04 04:45 PM
