Sporting Code Question
Old June 27th 12, 05:21 PM posted to rec.aviation.soaring
Peter von Tresckow
Default Sporting Code Question
Hi, a few weeks ago we had some great WX here in WI, and I was flying with a
friend and we got the Blanik up to 8000' MSL which (sadly) qualifies us for
the State Two Seater Absulute Altitude and Altitude Gain records.
Now the SC states that no declaration is required for altitude records
claimed with a barograph, unfortunately I used my Volkslogger. So in my VL I
still had an old task, but I failed to update the registration number/AC
type, and names of the pilots. I fear that I won't be able to use the trace
because the gliderID in the logger doesn't match the ID of the Blanik :-(
Am I hosed?
Peter
Old June 27th 12, 05:39 PM posted to rec.aviation.soaring
Grider Pirate[_2_]
Am I hosed?
Peter
I don't think so. Since the information regarding pilot, glider type,
and reg number are all about the 'electronic' declaration (which can
be superceded by a paper declaration) and NO declaration is required,
that should be irrelevant. Is the Volkslogger baro calibration
current?
Old June 27th 12, 06:40 PM posted to rec.aviation.soaring
Peter von Tresckow
Yep just came back from Paul on Monday.
Peter
"Grider Pirate" wrote in message
a
for
I
trace
Am I hosed?
Peter
current?
Old June 27th 12, 07:02 PM posted to rec.aviation.soaring
Marc
Please review SC3 Annex C section 10.3, it covers this situation...
Marc
Old June 27th 12, 07:08 PM posted to rec.aviation.soaring
You have a valid claim. Subject to the calibration and security requirements of your Flight Recorder, the claim should be approved.
The Sporting Code says (in SC3 4.5.6b) that the Official Observer must observe and record the Pilot and Glider identities, independent of the Flight Recorder.
Because a declaration is not required, the information in the Flight Log that we construe as the elements of an "electronic declaration" is irrelevant, and there is no consequence of it being wrong.
In short, the job of identifying you and the glider belongs to the Official Observer, not to the Flight Recorder.
We talked about this at the last IGC meeting (item 8.1.5):
http://tinyurl.com/cv4fjdw
Rick Sheppe
Am I hosed?
Peter
finding Sporting Code Section 3 - Gliding valid: 01.10.2004 through 01.10.2007 Hanka Z Soaring 6 November 12th 10 01:02 PM
Sporting Code Question Gary Emerson Soaring 6 March 24th 08 06:46 PM
Why does the Sporting code require "Goal" to be a finish point??? Mark Zivley Soaring 31 October 18th 04 10:31 PM
Why does the Sporting code require stephanevdv Soaring 2 October 17th 04 06:38 PM
FAI Sporting Code Section 3 experts wanted Stewart Kissel Soaring 28 September 1st 04 05:58 PM
