PowerFlarm antenna recommendation
Old April 7th 13, 06:30 PM posted to rec.aviation.soaring
Sam Discusflyer[_2_]
Default PowerFlarm antenna recommendation
Hi,
First let me acknowledge and thank those who are testing and
evaluating the location and installation of various antennae for best
performance for/with the PowerFlarm core/brick.
In the next week I will be installing the core and butterfly in panel
display in my V2b.
Has/can a recommendation be made by Flarm for the best
antenna to be installed in this glider?
I received the dipole with the core. Is this still the recommended
antenna for best performance with the core/brick?
Thank you for the response. I can give some feedback on my
experiences later this soaring season.
Steve Michalik
S9
Old April 7th 13, 08:34 PM posted to rec.aviation.soaring
bumper[_4_]
On Sunday, April 7, 2013 9:30:28 AM UTC-7, Sam Discusflyer wrote:
Hi,
Steve Michalik
S9
Steve,
The dipole is probably the best practical antenna available. If your glider nose is not carbon fiber, and you have reasonable clearance 3" from metal stuff, then installing one dipole on each side of the nose works well. Keep the center feed coax at right angle leading away from the antenna elements for a few inches too.
bumper
Old April 7th 13, 08:57 PM posted to rec.aviation.soaring
I cannot speak to "recommendations made by Flarm", but if you want to have a look at what I did in my V2C, you could go to my webpage.
https://sites.google.com/site/threeuniform/powerflarm.
In the antenna page you can see my results from the range analysis tool.
Old April 7th 13, 09:41 PM posted to rec.aviation.soaring
Dave Nadler
Hi Steve - I recommend the dipole, mounted as high as
practical. In the V2b this means on a support towards
the pilot end of the glare shield. Angle the coax
away from the dipole...
Hope that helps,
Best Regards, Dave
PowerFLARM antenna mounts Dave Nadler Soaring 52 August 14th 14 02:34 PM
Shortening PowerFLARM Brick Antenna and GPS cables kirk.stant Soaring 30 January 29th 13 04:27 AM
PowerFLARM Brick ADS-B antenna source? Paul Remde Soaring 14 October 16th 12 06:35 PM
PowerFLARM antenna mounts Dave Nadler Soaring 0 July 4th 12 05:11 PM
PowerFlarm antenna install Sam Zimmerman Soaring 10 November 11th 10 10:54 PM
