Colibri V1
Old June 4th 13, 11:20 PM posted to rec.aviation.soaring
Phil Chidekel
Default Colibri V1
Hi All,
I have been having a bit of trouble with my Colibri V1. The date and time seem to be stuck in October 1996, even after GPS reception is established. I believe the only adjustable part of this data is the time zone, which is adjusted correctly.
The logger was working perfectly two weeks ago.....
Any ideas?
Phil
Old June 4th 13, 11:29 PM posted to rec.aviation.soaring
WAVEGURU
Default Colibri V1
New battery?
Old June 5th 13, 12:33 AM posted to rec.aviation.soaring
Phil Chidekel
Default Colibri V1
Tim,
I will send you the file. My apologies, 1996 was a typo. Right now, I am in 1997, but the flight date was 1993. It has been jumping around....
Phil
I am a bit puzzled about the date of 1996, I would have expected a date
in October 1993, 1024 week before the actual flight.
This is not the same battery that records the seal on the recorder.
Old June 5th 13, 05:35 AM posted to rec.aviation.soaring
Paul Remde
Default Colibri V1
Hi Phil,
The unit's GPS engine or the battery for the GPS engine has failed. It can
only be repaired at LX Navigation.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
___________________________
"Phil Chidekel" wrote in message
Hi All,
adjusted correctly.
Any ideas?
Phil
Old June 5th 13, 04:52 PM posted to rec.aviation.soaring
Richard[_9_]
Default Colibri V1
On Tuesday, June 4, 2013 2:20:06 PM UTC-7, Phil Chidekel wrote:
Hi All,
Any ideas?
Phil
Possibly a new battery would solve the problem
Craggy Aero LLC can replace the battery and reset the seal.
Richard
www.craggyaero.com
Distinguishing an LX Navigation Colibri 1 from a Colibri 4? Papa3[_2_] Soaring 0 October 25th 12 03:49 AM
Colibri II Rick[_3_] Soaring 5 May 5th 12 01:33 PM
colibri ryanglover1969 Soaring 2 August 17th 09 01:44 AM
FS Colibri Ed Hollestelle Soaring 1 December 20th 06 04:00 AM
FS Colibri [email protected] Soaring 0 March 1st 06 01:26 PM
