Wing wheel for a Mini Nimbus
Old March 18th 14, 06:52 AM posted to rec.aviation.soaring
Van Henson
Default Wing wheel for a Mini Nimbus
A friend and I recently purchased a Mini Nimbus. I'm interested in acquiring a wing wheel to make it easy for one person to move the glider around.
Are there any out there and available?
Are there any out there and available that are going cheap?
Van
Van Henson
Mini Nimbus N301YC
Old March 18th 14, 04:28 PM posted to rec.aviation.soaring
Dan Marotta
They are very simple to make and don't have to be a really good fit. Any
cuff that will fit over the wing without pinching or flopping around will be
just fine.
"Van Henson" wrote in message
around.
Van
Van Henson
Mini Nimbus N301YC
Old March 19th 14, 01:09 AM posted to rec.aviation.soaring
Kevin Christner
http://www.wingsandwheels.com/page34.htm
just fine.
around.
Van
Van Henson
Mini Nimbus N301YC
Old March 19th 14, 06:15 AM posted to rec.aviation.soaring
If you want a wing wheel that really fits your wing profile and will not nibble nastily at aileron and flap trailing edges I would suggest that you contact Mark Mocho (M&M Fabrication). Tel: 505-298 2922. His wing wheels also work well in serious cross winds.
I am a well satisfied customer.
Van
Van Henson
Mini Nimbus N301YC
Old March 19th 14, 02:23 PM posted to rec.aviation.soaring
Mark628CA
Howard-
Thanks for the recommendation. Only problem with the post is the incorrect telephone number. I have moved to Moriarty from Albuquerque, and my cell number is 505 249-0161. Email remains the same: mark (at) mmfabrication (dot) com
I also disagree with Dan's assertion that a wing wheel doesn't have to be a very good fit. I have seen a bunch of damaged trailing edges and ailerons due to badly fitting wing wheels.
Old March 19th 14, 04:27 PM posted to rec.aviation.soaring
Dan Marotta
Sorry to disagree with you, Mark, but a tight fit on the left wing will not
work on the right wing. Think taper. I do agree, however, with what you
said about the trailing edge.
"Mark628CA" wrote in message
Howard-
(dot) com
FS - IMI Wing Wheel slbair Soaring 0 September 17th 13 05:27 PM
LS3a or Mini Nimbus [email protected] Soaring 14 November 11th 06 11:36 PM
Mini Nimbus for sale - N. California [email protected] Soaring 0 August 1st 06 05:14 AM
Nimbus 2c wing templates Robert Hart Soaring 7 March 3rd 06 06:25 PM
For Sale - Mini-Nimbus Frank Smith Soaring 1 February 25th 04 08:23 PM
