JetsGo MD-83 engine not working?
Old January 25th 05, 07:17 AM
Tyler Wordsworth
Default JetsGo MD-83 engine not working?
I flew JetsGo flight 178 (Toronto to Vancouver) on 19 January 2005. The
equipment was an MD-83.
I'm convinced the right-hand engine was not operational! I could not see
the turbofan spinning (looked stationary) and the flight took about an
hour longer than scheduled (they blamed strong headwinds).
Is this possible? Can/should/is it legal for a flight to take off and
fly an entire route with one engine? How much flight time would this add?
Are there publically-available safety logs that would record if this was
the case?
How are JetsGo's safety standards?
Lots of questions!
Thanks
S.
Old January 25th 05, 02:31 PM
tscottme
"Tyler Wordsworth" wrote in message
Never heard of a passenger aircraft intentionally taking off with one engine
inop. I forget if the engine used on MD-80 series has the "inlet guide
vanes" which appears like a stationary set of fan blades at the front of the
engine. If it does have IGVs that would look a bit like the engine not
turning. However, even if the engine had zero fuel supplied to it, it would
turn, or windmill, due to the air flow through it. Strong headwinds sounds
far more likely.
Scott
Liberals love America like OJ loved Nicole. - Ann Coulter
Old January 25th 05, 02:50 PM
Robert M. Gary
It wouldn't have been possible for the fan to not be turning. It turns
even when a slight wind hits it while sitting on the ramp. Whatever you
saw, it couldn't have been the inlet fan or turbine not spinning. It
would not be legal to take off w/o the engine running since the plane
must be able to continue a takeoff after one engine fails after a
certain point. If you already started minus one, that wouldn't work.
Old January 25th 05, 09:28 PM
Shkumbin Hamiti
Hi,
I am sure that there is no pilot in the world who would take-off any
multiengine airplane with one engine inop. (Disclaimer: some test pilots may
do something like that).
I don't know the company you flew with, but for sure the engine was working.
What can happen though is that the pilot may decide to turn off during the
flight an engine that may cause trouble, but in that case would likely
divert to the nearest suitable airport.
Regards,
Shkumbin
EFHF
the case?
Lots of questions!
Thanks
S.
Old January 25th 05, 10:42 PM
Tobias Schnell
On Tue, 25 Jan 2005 20:28:13 GMT, "Shkumbin Hamiti"
Oh, at least on four-engine transports this is done pretty regularly
to ferry the airplane where repairs can be accomplished.
Of course without pax and with some additional restrictions.
The infamous crash of an ATI-DC8 proves, however, that things can get
ugly in a heartbeat.
Tobias
Old January 25th 05, 11:50 PM
John
Well...there was the pilot in Portland, OR who tried to takeoff with one
engine inop in an Aerospatial (sp?)Corvette, with passengers. Everyone
survived and for some reason the pilot forgot what happened.
If I remember the report correctly, he was mentioning something about doing
an airstart on the engine that wouldn't start and the co-pilot said
something to the effect of "you are not serious, are you?".
"Shkumbin Hamiti" wrote in message
Hi,
may
working.
Regards,
Shkumbin
EFHF
add?
the case?
Lots of questions!
Thanks
S.
Old January 25th 05, 11:53 PM
John
Oops..forgot the link.
http://www.ntsb.gov/ntsb/brief.asp?e...11X09774&key=1
"John" wrote in message
news
doing
Hi,
may
working.
Regards,
Shkumbin
EFHF
The
see
add?
was
the case?
Lots of questions!
Thanks
S.
Old January 26th 05, 12:31 AM
Morgans
I hope that pilot lost his certificate....Permanently. What could have he
been thinking?
Old January 26th 05, 02:33 AM
Darrell S
Unless the aircraft was very light and/or the runway was very long that
MD-83 couldn't get off the ground on one engine. To take off with one
engine you would have to begin takeoff roll at low power setting on the good
engine and increase the thrust as more rudder authority became available at
higher speeds. It takes nearly full rudder to control yaw if the engine
fails just above V-1 speed with full power on the remaining engine.
JetsGo is a safe airline. I trained many of their pilots in the MD-80. No
airline pilot would attempt a takeoff with one engine out before start of
take off. I flew the B-52H which had 8 fan jets. Even with 7 remaining,
no one would attempt a takeoff in normal circumstances with an engine
inoperative.
Darrell R. Schmidt
B-58 Hustler History: http://members.cox.net/dschmidt1/
the case?
Lots of questions!
Thanks
S.
Old January 26th 05, 05:01 AM
Big John
John
In the Military I've heard about one jet being put in front of another
and the jet blast from the forward jet turning the dead engine of
bird behind up to enough RPM to get started.
Never heard of it being done with civilian jets however. Would be very
hard to do on a MD-80 type due to engines up on the fuselage in front
of the tail.
Big John
On Tue, 25 Jan 2005 14:50:06 -0800, "John"
Hi,
may
working.
Regards,
Shkumbin
EFHF
add?
the case?
Lots of questions!
Thanks
S.
ROP masking of engine problems Roger Long Owning 4 September 27th 04 08:36 PM
In-Flight Engine Failure O. Sami Saydjari Owning 59 April 30th 04 09:40 AM
Multi-Engine Before Commercial? David B. Cole Piloting 30 April 18th 04 05:46 PM
Emergency Procedures RD Piloting 13 April 11th 04 09:25 PM
Gasflow of VW engine Veeduber Home Built 4 July 14th 03 09:06 AM
