50mm Tailer Balls Available in US $8.95
Old April 28th 14, 07:56 PM posted to rec.aviation.soaring
JohnDeRosa
Default 50mm Tailer Balls Available in US $8.95
I stumbled upon this source for the difficult to find (in the US) 50mm trailer ball. Better yet the ball stud is 3/4", and not metric, so it is bound to fit your ball mount. No more asking your friendly airline pilot to buy some in Germany and having to evade customs on the way back. ;-)
http://www.etrailer.com/dept-pg-Ball...eter_Ball.aspx
Price: $8.95
Product Specs
50-mm Diameter Ball
1-1/2 Inch Shank Length
3/4 Inch Diameter Shank
3500 lbs GTW
Chrome
Old April 28th 14, 08:12 PM posted to rec.aviation.soaring
a 2 inch ball is within 2 mm of spec....
Old April 28th 14, 08:46 PM posted to rec.aviation.soaring
SoaringXCellence
But can be surprisingly "sloppy" on some trailers.
Old April 28th 14, 10:11 PM posted to rec.aviation.soaring
son_of_flubber
On Monday, April 28, 2014 3:46:51 PM UTC-4, SoaringXCellence wrote:
But (a 2" ball) can be surprisingly "sloppy" on some trailers.
2" = 50.8 mm ... So compared to a true 50 mm ball, why would a 2" ball be more sloppy on a 50 mm hitch?
Old April 28th 14, 11:58 PM posted to rec.aviation.soaring
Tony V
John Murray at Eastern Sailplane has had 50mm balls for a long time but
not at this price. I've seen one (Blanik enclosed) trailer That would
not fit on a 2 inch ball. It was 50mm or nothing. If your trailer is
designed for 50mm, maybe that's what you should have.
Tony "6N"
Old April 28th 14, 11:59 PM posted to rec.aviation.soaring
Tony V
Tony "6N"
Old April 28th 14, 09:01 PM posted to rec.aviation.soaring
The problem is which side of the spec it is on. It's really easy to get
the hitch stuck on the ball trying this. A 1-7/8" ball doesn't get stuck
and otherwise works OK (it's about 2.5mm too small). I've used one to
tow my trailer successfully. (The trailer came with a 50mm ball, but the
shank was 1" and my SUV had a Class II receiver so it could only take 3/4"
shank balls.)
This looks like a really great deal.
Matt
Old April 28th 14, 10:07 PM posted to rec.aviation.soaring
son_of_flubber
I wonder what is the actual size of this 50 mm ball? Tolerance is not stated.
I put the calipers on my 2" U-Haul brand ball and it measures 50.5 to 50.35 mm. Some of the chrome is scraped off after towing a Polish trailer for 2000 miles or so.
Old April 29th 14, 03:32 AM posted to rec.aviation.soaring
Dan Marotta
My LAK T5 trailer will not accept a 2" ball and a 1 7/8' ball is sloppy and
clunks a lot on the road. I have a friend at Moriarty who has a machine
shop and he machined my 2" ball down to 50 mm - *by hand*! It was a lot of
work, but he got it right and it tows perfectly. Still, I think I'm gonna
get me one of those $8.95 balls.
"son_of_flubber" wrote in message
stated.
Old May 2nd 14, 11:13 PM posted to rec.aviation.soaring
JohnDeRosa
I will measure the eTrailer 50mm ball when it comes in and report back.
hey hector , suck balls ! joe[_3_] Aviation Photos 0 April 1st 11 04:42 PM
Hi Tailer Jet Airplane Aerodynamics [email protected] Owning 5 December 9th 06 09:35 PM
Tow Hitch Ball - 50mm or 2"? ContestID67 Soaring 12 October 28th 06 05:53 PM
"Biggest balls" award at Oshkosh, or, Do I Just Lack Ambition? Mark Smith Home Built 22 August 13th 05 09:41 PM
50mm Hitch Ball John Scott Soaring 10 May 18th 05 01:41 PM
