Power Flarm in a Super Cub
Old January 30th 15, 09:40 PM posted to rec.aviation.soaring
Peter Wyld[_2_]
Default Power Flarm in a Super Cub
Does anyone have useful comments to make regarding Flarm aerial
placement in a Super Cub ? (Specifically Power Flarm, but regular Flarm
also valid )
I flew a Super Cub with a Flarm stuck on top of the panel a few weeks ago
and to be frank, it was crap.
If you have an installation which you think is good, please tell me about
it and ideally provide evidence from the Flarm range display websites
(preferably both transmit and receive).
For the uninitiated, receive quality can be shown on the Flarm Range Tool
web page http://www.flarm.com/support/analyze/index_en.html by
uploading an igc file from the Flarm and the transmit quality can be shown
online at http://www.kisstech.ch/flarm-liverange/ by inputting the Flarm
ID
(This only likely to work in Europe)
Pmail probably preferable if you want to send screenshots !
Many thanks.
Old January 31st 15, 03:55 AM posted to rec.aviation.soaring
George Haeh
If you have not yet read the notes on antenna placement, read them.
In our Scout I put the primary antenna on one of the diagonal crossbraces
in the baggage compartment. There's enough cable.
On the glareshield the engine, gas tank and pilot all block signals. With
that position you won't have to worry about a glider descending on top of
you.
The new Cores require a licence to enable the secondary antenna.
Old January 31st 15, 04:52 AM posted to rec.aviation.soaring
bumper[_4_]
I have a portable PowerFlarm on the glareshield of my Husky A1-B. It works acceptably well, but doesn't have the range of the PF Core I have installed in my ASH26E (which has the dipole antennas installed on either side in the nose ahead of the rudder pedals.
In the Husky, I wired a transistor driver that switches power to drive a small, super bright LED when there's an audio alarm. The LED is attached to the side of the PF with Velcro.
Power Flarm [email protected] Soaring 3 May 25th 14 11:03 PM
Power flarm [email protected] Soaring 10 March 24th 14 02:31 AM
Power Flarm Display SteveB_Z5 Soaring 64 March 25th 13 08:17 PM
Power FLARM as logger Lucky812 Soaring 27 December 7th 12 02:13 PM
Power FLARM deliveries? Andy[_1_] Soaring 1 June 5th 12 01:33 PM
