CNC Waterjet cutting instrument holes
Old February 26th 15, 09:05 PM posted to rec.aviation.soaring
Default CNC Waterjet cutting instrument holes
Hey All,
Does anybody have any experience with getting a fiberglass instrument panel CNC cut with a waterjet (or any other CNC cutter for that matter)? I called several local shops and I couldn't get a definitive answer whether the waterjet will delaminate the composite around the cut holes or not.
I've previously cut with bi metal hole saws and the hole turned out quite a bit too large and I trust a robot to measure a lot more accurately than myself. I was also interested in laser CNC cutting, but I'm pretty sure that will burn the composite around the edges of the cuts.
Any input would be appreciated.
Omri
Trying to fill some holes in the instrument panel [email protected] Soaring 2 February 12th 14 03:55 AM
Cutting 57mm holes in the instrument panel.....how to? John Bojack[_2_] Soaring 20 November 12th 10 10:15 PM
When Poorboys drill holes ...was: Drilling holes in steel tubing wright1902glider Home Built 4 November 4th 05 02:19 AM
Cutting shirttails??? Larry Dighera Soaring 11 September 3rd 03 04:34 PM
