Jump starting solo motor glider with automobile 12 volt starter
Old April 2nd 15, 08:01 PM posted to rec.aviation.soaring
Default Jump starting solo motor glider with automobile 12 volt starter
Could I use a car 12 volt jump cable starter, the kind that is a heavy duty rechargable battery used to start dead car batteries, to start my Ventus 2CXM if the battery runs down? Could I damage the electrics of the glider if I did so?
John Iacobucci
Old April 2nd 15, 08:16 PM posted to rec.aviation.soaring
Dave Nadler
I did so?
John Iacobucci
Um, you didn't purchase the "jump cable" option with the glider?
You've maybe seen me use it in "A Fine Week of Soaring"...
Sure, you can jump-start without the factory kit, but BE CAREFUL!
As long as its less than 14v or so.
I'm not sure how you'll safely connect the jumper cables though.
And, make a point of replacing that battery every yeary or two,
as it seems to degrade rapidly when called upon to deliver
starting current. The batteries are very inexpensive and it
saves a lot of aggravation.
Hope that helps!
Best Regards, Dave
PS: I'm ordering the jump-start kit with the new toy ;-)
Old April 2nd 15, 08:25 PM posted to rec.aviation.soaring
I'm getting a new toy soon and will be ordering the jump starter kit with it! Thanks for your reply. All the best -NB
Motor glider James C. Simmons Soaring 16 May 20th 09 09:46 PM
24 Volt starter for Chevy V8 larry Home Built 10 February 20th 09 05:55 AM
Blue Angel practice today - solo #6 starting steep climb Pensacola Beachcomber Aviation Photos 0 May 29th 08 10:43 PM
Motor Glider Endorcement Sam Giltner Soaring 3 October 30th 06 10:32 PM
FIRST MOTOR GLIDER ? Vorsanger1 Soaring 3 March 31st 04 07:03 AM
