50 MM ball for hitch
Old May 26th 15, 02:44 AM posted to rec.aviation.soaring
Jonathan St. Cloud
Default 50 MM ball for hitch
Anyone know where I may purchase 50 mm ball for hitch? Have ALKO stabilizer for trailer, which needs a 50 mm ball.
Old May 26th 15, 03:56 AM posted to rec.aviation.soaring
Papa3[_2_]
eTrailer for one. http://www.etrailer.com/Balls/Tow-Ready/63912.html Need to make sure the shank works with your bar, but there are a couple of 50mm options and the prices are good.
Old May 26th 15, 07:19 AM posted to rec.aviation.soaring
I believe I use a 1 7/8" ball for "Euro" trailers.
Old May 26th 15, 11:25 AM posted to rec.aviation.soaring
Mark628CA
If you are using the ALKO sway stabilizer that clamps tightly to the 50 mm ball, be sure you have a way to ensure that the ball cannot rotate, or the nut will become loose. I have installed several of these, and I machine a flat surface on the base of the ball and weld a steel bar across the hitch surface to preclude the ball from rotating.
These hitches work very well, but only with a 50 mm ball. US 2 inch is a bit too big and 1 7/8, while it fits in the hitch, is too loose for the clamp to work.
Old May 26th 15, 03:36 PM posted to rec.aviation.soaring
50 mm hitch ball, with 1 inch shank.
http://www.hitchcorner.com/trailer_balls.htm
GX
Old May 26th 15, 04:12 PM posted to rec.aviation.soaring
On Tuesday, May 26, 2015 at 12:19:27 AM UTC-5, Charlie M. (UH & 002 owner/pilot) wrote:
Don't do that Charlie! There's too much play between your ball and a 50 mm. Why don't we just go metric???
Old May 26th 15, 08:17 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Just too many years of being "different", I guess. Besides, Herb. To go from 2 inch to 50 mm would require shrinking our balls. :-)
Steve Leonard
Old May 26th 15, 10:17 PM posted to rec.aviation.soaring
Dave Nadler
A much-discussed topic in New England these days ;-(
Old May 27th 15, 07:47 AM posted to rec.aviation.soaring
SoaringXCellence
I bought a 50MM tow ball from W&W several years ago. they still list one for $24.95.
Old May 27th 15, 08:38 PM posted to rec.aviation.soaring
John Firth[_4_]
for $24.95.
Or, take a standard 2" ball to your local machine shop
and have them skim the 0.8 mm from the waist area.
JMF
new tow plane/tow hitch jim Soaring 9 March 17th 10 12:09 AM
Trailer Hitch Sam Giltner Soaring 3 January 11th 08 08:03 PM
STILL LOOKING for a Westbound hitch Paul Hanson Soaring 0 September 5th 07 03:48 AM
Tow Hitch Ball - 50mm or 2"? ContestID67 Soaring 12 October 28th 06 06:53 PM
50mm Hitch Ball John Scott Soaring 10 May 18th 05 02:41 PM
