Reducing PPG Concept Urethane
Old January 24th 16, 12:42 AM posted to rec.aviation.soaring
Default Reducing PPG Concept Urethane
I shot my first batch of PPG concept today, and it shot slower (and had more orange peel) than I expected. When I was shooting the primer, I accidentally over reduced it - and discovered that it sprayed much better. Smoother finish and faster spray.
I mixed the PPG per the instructions: 4 paint, 2 reducer, 1 hardener. I'm wondering if "over reducing" will make it spray better.
And also what are the risks of using too much reducer. I know it may run, but is there anything other than runs that I should be watching for?
John
Old January 24th 16, 01:06 AM posted to rec.aviation.soaring
John
I mix 8 to 5 to 2. This is 25% more reducer. Flows better. Better flow for me means less likelihood of going too heavy and making runs.
Good luck
UH
Old January 24th 16, 02:46 AM posted to rec.aviation.soaring
Thanks! Do you make any adjustments for cold weather?
Old January 24th 16, 03:03 AM posted to rec.aviation.soaring
Do you make any adjustments for cool weather?
Old January 24th 16, 03:52 PM posted to rec.aviation.soaring
Heat the paint........old painters trick. Works on gelcoat and rattle-cans too. If ambient temp is below 70f, I set the gallon of paint in a pot of boiling water (crack the lid). The guys at Prestec tell me their product should not be thinned. I'll be spraying gelcoat next week and max temp is 50'ish. Even with spray booth heated to 70, that doesn't last long with the exit fan on and remember the sudden release of pressure (at the nozzle) cools the product even more. BTW, this is what causes little water droplets to be sprayed onto your paint (if you don't have an adequate dryer)....... I'll be heating Prestec next week and will report back.
JJ
Old January 24th 16, 06:32 PM posted to rec.aviation.soaring
No.
Using slower reducer also helps flow out at the expense of recoat time. Even in cool(70 or less) shop I use medium temp reducer to get better flow out. It adds a few minutes between coats but makes it easier to get a bit better result.
For acrylic urethane I use a turbine HVLP system which gives a big pattern and has no water in the air. I can't make myself use my $400 gun for polyester topcoat so I do get a few fish eyes in that.
FWIW
UH
Old January 24th 16, 07:23 PM posted to rec.aviation.soaring
Keep paint products in heated office/house for 24 hours before shooting. Add reducer/thinner until happy with viscosity. Adjust gun meticulously. Keep gun clean or use $40 guns and replace often. Spray multiple coats rather than one thick one with California Curtains "runs". Adjust air pressure to your liking. You want good atomization. Use water traps (that's plural). Good lighting in work area.
Manufactures recommendations are just that. My mentor laughed when I first showed him the instructions. Yea right was his response.
Good luck.
Lane
Old January 24th 16, 07:24 PM posted to rec.aviation.soaring
Jonathan St. Cloud
I know nothing of refinishing work, but just curious why people would use gelcoat when you can use urethane paint. I just paid an extra $4,500 for the urethane option on a new glider. They tell me I will never have to refinish, (except for spar cap shrinkage).
JJ
Old January 24th 16, 07:29 PM posted to rec.aviation.soaring
JJ
I sprayed my Cirrus with Prestec last winter. UH gave me valuable advice. In the end I thinned it down like Urethane. Sprayed very nice with minor polishing out required. It was a pleasant experience. Now removing the old gel coat was not pleasant. But you've been to that rodeo many times!
Lane
Old January 24th 16, 07:30 PM posted to rec.aviation.soaring
For that classic look. And the ease of future repairs.
Lane
Urethane Paint Jonathan St. Cloud Soaring 44 November 20th 15 11:48 AM
urethane 2K paint [email protected] Soaring 1 February 5th 14 12:30 AM
Reducing canopy glare caused by instrument face reflections. [email protected] Soaring 1 November 11th 13 10:22 PM
Reducing Fuel use and Increasing your car speed with FFI MPG-CAPS sexy girl Piloting 0 February 23rd 08 06:47 AM
Reducing the Accident Rate Snowbird Piloting 92 July 22nd 04 02:31 PM
