Powerflarm transmit antenna defect
Old May 19th 16, 07:34 AM posted to rec.aviation.soaring
Default Powerflarm transmit antenna defect
A big Thanks to Rex Mayes at Williams Soaring Center for a replacement Plarm A antenna. I installed the new one and TG reports now seeing me at 6nm! instead of less than 1nm.
The original antenna delivered with the unit actually had a short, unknown to me as others reported actually being able to see me at short distances despite this flaw(found at the crimp of the SMC connector). If others have transmit range issues, then consider ohming out your antenna and check for a short.
Darren
Old May 20th 16, 04:06 AM posted to rec.aviation.soaring
son_of_flubber
What should the ohm readings be for healthy Flarm antennas?
Old May 20th 16, 08:48 AM posted to rec.aviation.soaring
bumper[_4_]
Measuring from the coax connector center pin to the outer housing, should read open or infinite ohms.
To check the antenna without an RF type SWR meter, you would need to either remove the vinyl caps on the radials (if it's a dipole antenna) and measure those. One should read a short to either the coax center pin or outer housing, and the other radial should be a short to the other part of the coax fitting. It's a simple antenna with no loading coils or baluns etc.
If working on avionics a lot, there are testers like this available: http://www.mfjenterprises.com/
bumper
MKIV & QV
Old May 20th 16, 07:10 PM posted to rec.aviation.soaring
Ramy[_2_]
I suspect this may be a common problem with the stock antennas. In my case it was a bad ADS-B antenna.. I heard of others with antenna issues.
I recommend folks who have poor range issue with antennas that are installed properly to simply try with another antenna.
Ramy
Old May 20th 16, 09:52 PM posted to rec.aviation.soaring
Yep, simply check for open. This coax has no characteristic impedance unlike other coax types used for video, for example.
Also for the PF designers if they are reading, would be good to sense this case as is done on the Becker Transponder and issue an error. I imagine there a number of ways to do it, like a self test during boot.
Old May 20th 16, 10:48 PM posted to rec.aviation.soaring
scratch that comment about the coax impedance. Darryl rightfully pointed out it will have a characteristic impedance. But we are interested in whether the core and shield have been bridged here.
Old May 20th 16, 11:55 PM posted to rec.aviation.soaring
I have very poor forward performance from my powerflarm, who could I send photos of the install and range analysis image to get some suggestions?
In the mean time I should test the flarm antenna if i can figure out the correct procedure.
Chris
Old May 21st 16, 01:10 AM posted to rec.aviation.soaring
but that requires extra components and (therefore) extra expense.
Probably right. Simplest solution is for them to do a QA check on the antennas before delivery with the unit.
So easiest way to check the Pflarm A antenna, if you have access to the box itself is simply unscrew it from port A. And get out an ohm meter and carefully probe the inner core socket(middle of the white nylon bush) vs the outer "nut" which is tied to the shield. It should read infinite. If using the continuity feature of your multimeter it should NOT sound the high pitched beeeeep. verify again. if good, carefully screw the antenna back onto the proper/same port A and careful not to cross-thread. do not attempt to attach to any other port.
Old May 21st 16, 07:46 AM posted to rec.aviation.soaring
Ramy[_2_]
I should point out that this will detect only one type of failure. Another one could be a disconnect which make the antenna similarly useless. There could be other failure modes. So if you still have issue try to borrow an antenna from someone else or just spend the $30 or so for a new antenna. Another option is to swap the antennas for testing (they are almost identical) but this will require a reverse gender adapter.
Ramy
Dreaming of a BETTER PowerFLARM antenna [email protected] Soaring 27 November 12th 15 04:24 PM
second PowerFlarm antenna Andrzej Kobus Soaring 10 November 2nd 15 04:39 PM
PowerFLARM antenna separation kirk.stant Soaring 5 June 5th 15 06:42 AM
PowerFlarm antenna recommendation Sam Discusflyer[_2_] Soaring 3 April 7th 13 09:41 PM
PowerFlarm antenna install Sam Zimmerman Soaring 10 November 11th 10 10:54 PM
