Metric Spring Steel
Old June 14th 16, 01:25 AM posted to rec.aviation.soaring
vontresc
Default Metric Spring Steel
Anyone know where I might find a small quantoty of 20 x 3mm spring steel to rebuild the tail spring on my Ka-6?
It suffered a hard landing and one of the leafs got buggered up pretty badly. All I can find at the usual sustpects (McMaster and Grainger) is mild 1008/10018 steel in that size.
Thanks
Peter
Old June 14th 16, 02:16 AM posted to rec.aviation.soaring
Thanks
Peter
I had to do a similar search about 10 years ago,[metric square tubing] If you search Metric Steel USA you can find a few vendors, here are a couple.
https://www.metricexpress.com/?gclid...2P8aAuEy8P8HAQ
http://www.metricmetal.com/
Chris
Old June 14th 16, 03:31 AM posted to rec.aviation.soaring
AS
Thanks
Peter
Peter - try www.onlinemetals.com. They may be able to help you.
Uli
Old June 14th 16, 03:38 AM posted to rec.aviation.soaring
Peter you can do as I did once, buy a piece of SAE spring steel just a little thicker than you need and then bring it to any machine shop, they can shave it down to any desired thickness.
Dan
Old June 14th 16, 05:29 AM posted to rec.aviation.soaring
Stephen Damon
Try cross-cut saw blades and some large hand saws, possibly large bandsaw blades!
Old June 14th 16, 01:10 PM posted to rec.aviation.soaring
AS
Not a bad idea! I looked at machine hack saw blades. The thickest one I could find is .1" thick and 2-1/8" high.
http://www.mcmaster.com/#hacksaw-blades/=12ujos2
Not sure how 'springy' or hard these blades are, though but worth a try.
\Uli
Metric Instruments Roy Bourgeois Soaring 29 May 27th 13 02:53 PM
Metric Soaring Paul Hanson Soaring 23 September 20th 07 02:38 PM
VW engines by metric AP [email protected] Home Built 15 August 7th 07 04:48 PM
Metric Instruments? AFSax Soaring 14 August 24th 05 03:52 PM
Suitable coating for spring-steel wire? Wright1902Glider Home Built 6 February 9th 04 05:12 PM
