If the Flarm B antenna is "receive only" and same for the ADSB antenna, is there any issue mounting those two antennas next to each other, or very nearly so?
On Wednesday, November 16, 2016 at 9:03:00 PM UTC-5, wrote:
If the Flarm B antenna is "receive only" and same for the ADSB antenna, is there any issue mounting those two antennas next to each other, or very nearly so? From the CORE manual - 5.3.8.2 ADS-B/SSR antenna (SMA connector, BLUE marking) PowerFLARM Core ADS-B has one ADS-B/SSR receiver operating on 1090 MHz. Ensure that the antenna cable is properly and fully screwed into the device. Never swap the FLARM and the ADS-B/SSR antennas. Use only little force when inserting and tightening (1 Nm max). This antenna should be placed at least 30cm/1 ft away from the FLARM antennas. The FLARM antennas have priority over this antenna for best placement. In addition, in 5.3.9 - GPS Antenna, at the end: If more than one GPS antenna is present in the aircraft, it is recommended that they are at least 30cm/1ft apart; the same holds for separation from all other antennas connected to PowerFLARM Core. |
| Thread Tools | |
| Display Modes | |
| Transponder Antenna Placement Fuselage Bottom - Minimize Damage?Exact Location | WaltWX[_2_] | Soaring | 9 | January 20th 15 12:00 AM |
| FLARM antenna mounts for ASG-29 | Sean F (F2) | Soaring | 20 | September 11th 13 03:35 PM |
| Transponder Antenna & Battery Placement Nimbus or DUO | [email protected] | Soaring | 13 | February 25th 09 10:02 PM |
| FLARM antenna installation | Kevin Neave | Soaring | 5 | January 16th 07 07:53 PM |
| Nav Antenna Placement | Jim Pensinger | Home Built | 7 | October 4th 04 10:55 PM |
