Battery charger question
Old July 2nd 17, 02:11 AM posted to rec.aviation.soaring
Default Battery charger question
I know that the lithium iron phosphate batteries should be charged with a different charger than SLA batteries but can a "lithium" charger be used on an SLA?
Old July 2nd 17, 02:48 AM posted to rec.aviation.soaring
JS
MDFA, there are quite a few deals on LiFePO4s that include a charger for $15 to $25 more than just the battery.
Use that charger for the new battery and your existing charger for the old SLA / AGM battery.
Charge voltage is similar, "float" isn't.
Old July 2nd 17, 05:47 AM posted to rec.aviation.soaring
My Lifepo4 11ah battery is charged at 5 amp rate, total charge time is 2-2.5 hours. At that rate you would burn up or dry out similar lead acid agm batteries just say no!
Old July 2nd 17, 06:24 PM posted to rec.aviation.soaring
Matt Herron Jr.
I bought 2 4A chargers and two 9AH LifePO4 from stark. Batteries work fine, but the charger will blow a 5Amp fuse when the battery is first plugged in. I am a little worried about putting a higher amperage fuse in the battery. Anyone else have this experience with the stark chargers?
Old July 2nd 17, 06:46 PM posted to rec.aviation.soaring
Because I'm also into "battery RC", I have a selection of battery chargers.
I use a few different Venom chargers that can do NiCad, NiMH, LA, LiFe, etc. most can be powered by a wall outlet at home, or 12VDC in the field.
Look on RC hobby sites (Tower Hobby, local place, etc.) and look up specs for Venom ProChargers. See what you think.
Note, most can also do automated charge/discharge cycles to measure battery capacity, nice thing to do late winter before flying.
PS, yes, if you look close, several brands all look the same, different "mfr" or model name, I believe Venom is the actual mfr.
Old July 2nd 17, 06:50 PM posted to rec.aviation.soaring
Dave Nadler
Yikes. what does stark say about this???
Old July 2nd 17, 06:56 PM posted to rec.aviation.soaring
Go to a 6 or 8A fuse and you should be fine
Old July 2nd 17, 10:07 PM posted to rec.aviation.soaring
Fuses protect the wires, look up the ampacity of the wires used. As an example, 12ga is good for 20 Amps, 10ga is good for 30amps 14ga is good for 15 amps.......
Old July 3rd 17, 03:44 AM posted to rec.aviation.soaring
Dan Daly[_2_]
I have a 5A charger (the original Silver one with the fan from Knauff and Grove (I was an early adopter when an SLA failed at the Ridge); now they have the black ones) and two 9AH LiFePO Stark batteries; had them all for two years, never blown a 5A auto fuse on battery or the charger fuse. I use 16 AWG cable.
Dan
Socket Mobile Battery/Charger John[_27_] Soaring 9 July 29th 12 08:44 PM
Basic battery charger question RS Soaring 5 March 19th 12 04:03 AM
For Sale: 14 volt battery charger Jim[_23_] Soaring 0 August 23rd 09 08:18 PM
Battery Charger [email protected] Soaring 5 February 5th 07 07:41 AM
Jim Weir - desulfating battery charger Ernest Christley Home Built 5 December 21st 06 11:28 PM
