Komet Trailer
Old July 28th 17, 05:52 PM posted to rec.aviation.soaring
Default Komet Trailer
Hi all,
I have recently taken a significant upgrade in trailers for my Libelle from a cigar tube trailer to a Komet. We adjusted it to go from a Discus to a Libelle and it is so much nicer to rig and de-rig out of. Trailers matter!
I have two questions, if I have to reweld a support bar on the clam shell and a small crack in the area of metal that holds the clam shell down during transport, has anyone had to re-weld some of there Komet, if so please let me know what steps you took.
My final question is what I should do to prevent water and other things from getting in between the clam shell and the trailer door in the back. I was thinking of putting a piece of wood in between unless someone has a better idea? Thanks.
https://ibb.co/j2dhh5 --- Photo of gap in between the clam shell and trailer door needing to be weather sealed.
Old July 29th 17, 03:14 AM posted to rec.aviation.soaring
Ben Coleman
I am far from an expert on these but have had one for a few years. I had a local welder repair a few spots and I believe he tig welded them. If hard against the fibregalss it will probably need some heat shielding during welding.
At the back your gap looks a little larger than expected but I could be wrong. There should be a hard rubber strip on top of the rear door for when it rests on the ground and a sealing strip (soft rubber) atrached to the lid to fill the gap.
Cheers Ben
Old July 31st 17, 08:02 PM posted to rec.aviation.soaring
Cheers Ben
Thank you!
Old August 2nd 17, 01:09 AM posted to rec.aviation.soaring
ZP
As far as the gap... I took medium density foam and glued it full length to the lift gate. When you close the tail gate, it compresses the foam slightly making the seal. A simple rectangular piece of foam works great for dust, but if you want to seal it from rain, you'll have to use a much thicker piece of foam (~1.5 in or so). It will need to be cut so that the foam provides a roof over the tailgate, but thin where the tailgate closes. Cross-section below....
________
| (foam) | --(lift gate side - clamshell)
|____ | (glue this edge to lift gate)
/\ | ||___|
| | --(tailgate - closed position)
Old August 2nd 17, 01:10 AM posted to rec.aviation.soaring
ZP
crap. it looked so good before I hit the "post" button. wish they would leave the font in courier.
Old August 2nd 17, 01:24 AM posted to rec.aviation.soaring
Dan Marotta
Hey Dirk,
It looks like courier on my computer.
Dan, 5J
Old August 2nd 17, 01:52 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Looked good here (using PAN 0.141 as newsreader). Some newsreaders (PAN
is one) let you set the font used for different window types: I use
'monospaced' for everything. Is it possible that your edit window is
using Courier but the window/panel your usenet reader uses to display
incoming posts is using a variable width font?
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old August 7th 17, 06:34 AM posted to rec.aviation.soaring
________
/\ | ||___|
Thank you!
Komet Trailer Rebuild Robert Ballou Soaring 12 April 20th 15 08:21 PM
Komet Trailer Question Jay Allardyce Soaring 9 December 3rd 11 01:16 AM
Trailer tires for old (1981) Komet Trailer [email protected] Soaring 3 May 13th 09 11:24 PM
Komet Trailer gas struts HL Falbaum[_2_] Soaring 13 February 1st 09 02:05 PM
Old Komet Trailer thermalrider Soaring 7 October 11th 08 05:13 PM
