I just had the O-235-L2C in my Tomahawk overhauled, and the 125 HP mod performed at the same time. Now it is getting 2700 RPM at just under 400 degrees CHT, during break in, and cruising between 100-105 knots. Before the rebuild, cruise was about 2400 RPM and about 90 knots. I'm very happy with the engine mod, and would recommend it to anyone getting an O-235-L2C overhauled. Paul Missman |
mind sharing some prices with & without the hp upgrade??
thx dan |
The CHTs are too hot. Check your fuel flow, check the baffles. Even
new, you don't want those CHTs that high! That's the recipe for cylinder problems. On Mon, 14 Feb 2005 21:11:42 -0500, "Paul Missman" wrote: I just had the O-235-L2C in my Tomahawk overhauled, and the 125 HP mod performed at the same time. Now it is getting 2700 RPM at just under 400 degrees CHT, during break in, and cruising between 100-105 knots. Before the rebuild, cruise was about 2400 RPM and about 90 knots. I'm very happy with the engine mod, and would recommend it to anyone getting an O-235-L2C overhauled. Paul Missman |
Tomahawks are infamous for relatively high CHT's. The modification to 125
hp makes it even worse. I'd say that 400 degree CHT's on a brand new engine at full power during break-in ain't half bad for a 125 hp Tomahawk. Paul could post his question to the Tomahawk group in Yahoo, and I think he'd find that these temperatures are typical or maybe better than typical for this installation. KB "Jon A." wrote in message ... The CHTs are too hot. Check your fuel flow, check the baffles. Even new, you don't want those CHTs that high! That's the recipe for cylinder problems. On Mon, 14 Feb 2005 21:11:42 -0500, "Paul Missman" wrote: I just had the O-235-L2C in my Tomahawk overhauled, and the 125 HP mod performed at the same time. Now it is getting 2700 RPM at just under 400 degrees CHT, during break in, and cruising between 100-105 knots. Before the rebuild, cruise was about 2400 RPM and about 90 knots. I'm very happy with the engine mod, and would recommend it to anyone getting an O-235-L2C overhauled. Paul Missman |
On Tue, 15 Feb 2005 21:46:20 -0500, "Kyle Boatright"
wrote: Tomahawks are infamous for relatively high CHT's. The modification to 125 hp makes it even worse. I'd say that 400 degree CHT's on a brand new engine at full power during break-in ain't half bad for a 125 hp Tomahawk. Paul could post his question to the Tomahawk group in Yahoo, and I think he'd find that these temperatures are typical or maybe better than typical for this installation. Never offer up factual information to a demagogue, it's like trying to teach a pig to sing. Regards; TC |
"houstondan" wrote in message oups.com... mind sharing some prices with & without the hp upgrade?? thx dan Dan, I can't answer as to overhauls, as prices will vary from one engine shop to another. The engine shop I used charges $13k to overhaul an O-235-L2C, which includes inspection and casework, inspection and possible replacement of the cam, inspection and possible replacement of the crank, new cylinders and pistons, new mags, plugs, wires, etc.. The 125 HP upgrade consists of installing 9.3:1 compression pistons, and, if not already in place, an external oil cooler. From Air Mods NW, which holds the STCs, I purchased the STCs, an external oil cooler and shrouds, and an EGT/CHT guage. I let the engine shop supply the high compression pistons, and the oil cooler hoses, and install the oil cooler and CHT/EGT. Between my engine not needing a few accessories in the overhaul, and the extra work for the mods, I paid $14k to the engine shop, which also put in new engine mounts, repainted the mounting brackets, and did a beautiful job with the wiring. I paid Air Mods NW for the STCs, the oil cooler and shroud, and the EGT. I cut and pasted their prices from www.pipertomahawk.com below : BASIC KIT PRICES FOR THIS MODIFICATION Packet of 3 STC's, Engine, Airframe, & Oil Cooler$ 495.00 Set of 4 high compression pistons, weight matched$ 652.00 Pistons only - no rings, pins, plugs, etc. included Basic Kit Price, plus freight and applicable tax$1,147.00 Pre-Cut Materials Kit for Oil Cooler Mount$ 245.00 Ken Blackman, from Air Mods NW, started this mod years ago with a Grumman that he had purchased years ago. He's quite happy to talk with people about the modification, and its history, when he has the time. He has had it placed in quite a few Tomahawks and a lot of Cessna 152s. Paul Missman |
"Jon A." wrote in message ... The CHTs are too hot. Check your fuel flow, check the baffles. Even new, you don't want those CHTs that high! That's the recipe for cylinder problems. Jon, The engine shop that did the overhaul told me, for the first 10 hours, to run it full rich, and everything short of either red line or 400 degrees CHT. With the mod, about 2700 RPM is just below 400 degrees CHT, and the red line is now 2800 RPM. I bought the EGT/CHT guage at Ken Blackman's recommendation. He's the holder of the 125 HP STCs. He recommended the guage, because, he said, in climb, at 9.3:1 compression, it can get quite hot, very quickly, and not to exceed 450 degrees. Normally, the Tomahawk has no CHT/EGT guage. So, I never knew how hot the cylinders ran before the modification. Paul Missman |
Between my engine not needing a few accessories in the overhaul, and the extra work for the mods, I paid $14k to the engine shop, which also put in new engine mounts, repainted the mounting brackets, and did a beautiful job with the wiring. I paid Air Mods NW for the STCs, the oil cooler and shroud, and the EGT. Also, included in that price, they pulled the tach, and sent it out for re-calibration and repainting of the red line. Paul |
Appreciate the reply, even the blurb from Pope Toecutter the 1st, but
if you have a look at the real data being measured today (the 21st century) you'll see that the Old Wive's Tales aren't holding any water. Regardless, you make your own decisions. http://www.advancedpilot.com/ On Wed, 16 Feb 2005 19:53:19 -0500, "Paul Missman" wrote: "Jon A." wrote in message .. . The CHTs are too hot. Check your fuel flow, check the baffles. Even new, you don't want those CHTs that high! That's the recipe for cylinder problems. Jon, The engine shop that did the overhaul told me, for the first 10 hours, to run it full rich, and everything short of either red line or 400 degrees CHT. With the mod, about 2700 RPM is just below 400 degrees CHT, and the red line is now 2800 RPM. I bought the EGT/CHT guage at Ken Blackman's recommendation. He's the holder of the 125 HP STCs. He recommended the guage, because, he said, in climb, at 9.3:1 compression, it can get quite hot, very quickly, and not to exceed 450 degrees. Normally, the Tomahawk has no CHT/EGT guage. So, I never knew how hot the cylinders ran before the modification. Paul Missman |
| Thread Tools | |
| Display Modes | |
| ROP masking of engine problems | Roger Long | Piloting | 1 | September 25th 04 08:13 PM |
| Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 07:42 PM |
| Autorotation ? R22 for the Experts | Eric D | Rotorcraft | 22 | March 5th 04 07:11 AM |
| Motorgliders and gliders in US contests | Brian Case | Soaring | 22 | September 24th 03 01:42 AM |
| Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 05:29 AM |
