IGC-approval for the LXNAV PowerMouse-IGC Flight Recorder
Old February 19th 18, 12:48 PM posted to rec.aviation.soaring
Ian Strachan[_3_]
Default IGC-approval for the LXNAV PowerMouse-IGC Flight Recorder
I am pleased to announce IGC-approval for the LXNAV PowerMouse-IGC Flight Recorder for flights up to and including Diamonds. The manufacturer is LXNAV d.o.o. of Celje, Slovenia, and the main firmware inside the recorder is by FLARM.
The IGC-approval document may be downloaded from either the GFAC or FAI/IGC web sites, see below, together with other information on IGC-approved Flight Recorders.
Ian Strachan
Chairman, IGC GNSS Flight Recorder Approval Committee (GFAC)
www.ukiws.demon.co.uk/GFAC
There are now 59 different types of IGC-approved Flight Recorders from 20 different manufacturers.
If you own or fly with one of these recorders, it is recommended that you download its latest IGC-approval document from one of the web sites given below, and note any changes that may affect how you operate it.
A table of all IGC-approved FRs with links to Approval Documents is the first item on the web site before the set of Approval documents for each type of recorder. This includes the following:
(1) a table of all types of IGC-approved Flight Recorders in alphabetical order of manufacturer name, with links to their IGC-approval documents in the right hand column under "Date of Latest Document".
(2) a table of Manufacturers of IGC-approved Flight Recorders, in alphabetical order of name.
(3) a diary of all IGC-approval activity from the first IGC-approvals in 1996 to the present day, most recent events first.
(4) a history of GNSS Flight Recording in IGC together with pictures of some early Recorders.
For the GFAC web site, see: www.ukiws.demon.co.uk/GFAC - the complete table can be viewed directly at:
www.ukiws.demon.co.uk/GFAC/igc_approved_frs.pdf
Navigating the IGC web site:
go to: www.fai.org/igc-documents
Scroll down and click "Flight Recorders",
look down and click on: "IGC-approved Flight Recorders - Approval Documents"
then click on "IGC-approval Documents for all IGC-approved Flight Recorders"
This will call up a list of documents, the first one being:
"Table - all IGC-approved FRs - links to Approval documents - General IGC FR info & history"
This table lists the name and main characteristics of individual IGC-approvals and in the last column of this table there is a link to individual documents, click the link for the document to be called up
The table is followed by a list of individual IGC-approval documents in alphabetical order of manufacturer’s name from Aircotec to Zander. These can be called up by clicking on the document name.
IGC-approval - GENERAL
IGC-approval follows test and evaluation by the IGC GNSS Flight Recorder Approval Committee (GFAC) in accordance with Annex B to the Sporting Code for gliding and the Technical Specification for IGC-approved GNSS Flight Recorders.
The Technical Specification is available through the igc-documents web site above
or
directly from the GFAC web site:
http://www.ukiws.demon.co.uk/GFAC/do..._spec_gnss.pdf
Programs that have been notified to IGC for the analysis of IGC files are listed on the GFAC web site under: " Analysis Programs for IGC Flight DataFiles "
The IGC Shell program for Validation of the structure of IGC files may be downloaded he
www.ukiws.demon.co.uk/GFAC/downloads.htm
This downloads the file IGCDLL.zip, which when un-zipped, gives the free IGC Shell program. This web site also contains the latest FR Manufacturers’ Data Link Library (DLL) files that are used by IGC Shell and other programs to Validate the structure of an IGC file. The IGC file Validate check ensures that the IGC file came from a serviceable and secure FR, and the file is identical to when it was originally downloaded. This check is required before a flight performance recorded in the IGC file can be approved to the standards of IGC.
Finally, the Sporting Code for gliding (SC3) and its annexes A-D may be downloaded via: www.fai.org/igc-documents in which SC3 is at the top of the list
IGC approval - LXNAV Nano 4 Flight Recorder [email protected] Soaring 4 February 21st 17 06:37 PM
IGC approval for the LX9000HAFR Flight Recorder Ian Strachan Soaring 0 August 3rd 16 11:29 PM
IGC approval for S-10 and S-100 Flight Recorders made by LXNAV Ian Strachan Soaring 0 April 29th 16 07:49 AM
IGC-approval for Triadis RU2 and update to LXNAV externalMeans-of-Propulsion recorder box Ian Strachan Soaring 0 May 7th 13 04:24 PM
IGC-approval of the LXNAV Nano GNSS Flight recorder Ian Strachan Soaring 5 September 1st 10 03:41 PM
