Transflex 02 Transponder Antenna
Old April 16th 18, 01:52 PM posted to rec.aviation.soaring
Kibby
Default Transflex 02 Transponder Antenna
Looking for a Transflex 02 transponder antenna for my Discus-2T. Don't see any at W&W or Cumulus. Does anyone in the US offer this antenna? thanks, Bob Kibby Discus-2T N722BK
Old April 17th 18, 01:33 AM posted to rec.aviation.soaring
Scott Williams
I see from an online search that the transflex 03 is available from vendors in Europe. I don't know how to link a similar thread "filser flexible antenna" from 2015.
good luck,
Scott
Old April 17th 18, 01:36 AM posted to rec.aviation.soaring
Scott Williams
correction, "filser transponder antenna"
I see from an online search that the transflex 03 is available from vendors in Europe. I don't know how to link a similar thread "filser transponder antenna" from 2015.
good luck,
Scott
Old April 17th 18, 07:39 AM posted to rec.aviation.soaring
bumper[_4_]
Not what you are after, but less drag. Can be special ordered with a threaded hole instead of mounting studs, no additional. This allows mounting with brass threaded rod with filed notch for breakaway if on belly.
http://www.deltapopaviation.com/Ultr...r_Antenna.html
bumper
Old April 17th 18, 01:31 PM posted to rec.aviation.soaring
AS
bumper
..... but less drag.
Careful here. If you install this type of antenna on the fuselage off the centerline in an area where the fuselage is necking down and you don't know the exact flow conditions in this spot, you may have it sitting slightly sideways.
Not exactly comparable to a glider but to show what I mean, take a look at his kind of antenna mounted to the belly of power planes. One side is typically black from the exhaust and oil coming from the engine due to the spiraling prop-wash airflow. The airflow is not parallel to the centerline at this spot and the paddle antenna will create a bit more drag.
Uli
'AS'
Old April 17th 18, 05:18 PM posted to rec.aviation.soaring
bumper[_4_]
bumper
.... but less drag.
Uli
'AS'
Watch this short old video comparing drag of various shapes - from a drag perspective, you can't do much worse than round except maybe a flat plate!
https://www.youtube.com/watch?v=ftq8jTQ8ANE
bumper
Old April 17th 18, 06:07 PM posted to rec.aviation.soaring
AS
bumper
.... but less drag.
Uli
'AS'
bumper
Thanks for the link, Bumper! I even do have Asher Shapiro's book 'Shape and FLow' and am well aware of this ~10:1 ratio. All I am saying is that the advantage is reduced, if the flat antenna is not aligned properly with the flow.
I have the stick antenna installed and plan on 3D-printing a free moving, self-aligning airfoil for it. That should take care of the bad drag of the round wire.
Uli
'AS'
Old April 17th 18, 10:46 PM posted to rec.aviation.soaring
Bob Kuykendall
Aeronautic engineer and sailplane pilot Steve Smith did the exterior profile on this antenna. It's about as good as you can do on a protruding antenna.
--Bob K.
Transponder Antenna Rick Fuller Soaring 6 January 30th 08 06:03 PM
VHF & Transponder antenna Steve Home Built 1 December 6th 04 04:29 PM
Oil on transponder antenna Bob Owning 12 May 9th 04 08:59 PM
Transponder and antenna Paolo Soaring 1 March 6th 04 03:32 AM
Wanted: Transponder antenna Grandpa B. Home Built 22 November 28th 03 08:03 AM
