Parachute source for gliders and winches
Old October 31st 18, 04:06 PM posted to rec.aviation.soaring
JS[_5_]
Default Parachute source for gliders and winches
Saw the ad in the AMA flyer for their Expo in Pomona. SSA Region 12 has a presence there.
AMA Expo:
https://amablog.modelaircraft.org/am...m-2018-web.pdf
Fruity Chutes looks like a good source for chutes, including ballistic chutes.
Anything from 12" diameter up.
https://fruitychutes.com/
Old November 1st 18, 11:05 PM posted to rec.aviation.soaring
Soartech
In case you did not know it, there are many small (~3 foot diameter) parachutes available for minimal cost on Amazon, Walmart.com, etc. Search on running parachutes, drag chutes, exercise parachutes, etc. They are used to add drag to increase effort during exercise.
Old November 11th 18, 02:27 AM posted to rec.aviation.soaring
son_of_flubber
The parachutes used at the end of the winch cable need to be very heavy duty.
They get dragged along the ground at high speed when the line is rewound onto the spools after the glider releases.
One time I stress-tested the parachute by putting it into a fast moving river that ran parallel to the runway. Newbie me did not adequately compensate for a strong crosswind on a 2000 foot AGL launch. The parachute opened and caught the current.
Old November 2nd 18, 12:18 AM posted to rec.aviation.soaring
Martin Gregorie[_6_]
a presence there.
AMA Expo:
https://amablog.modelaircraft.org/am...8/10/expowest-
program-2018-web.pdf
chutes.
The Fruity chutes I looked at would all be unlikely to survive their
first winch launch: thie all emphasized light weight, which is exactly
what you don't want for winching. The winch parachute is inline between
cable and shock cord. The tension being carried through the 'chute keeps
it closed during the 60-65 knot launch, when the 'underside' of the
'chute is facing the winch and the shock cord, connecting chute to
glider, it attached to the top centre of its bell. If the launch didn't
finish it off a light weight chute, then being dragged back to the winch
after the launch would probably do the trick.
That is why traditional winch chutes are made of heavy duty canvas with
typically four shrouds made of 50-75mm heavy duty webbing sewn onto the
shock cord attachment at the centre of the chute. Current manufacture
chutes often use plastic fabric, but its just as thick as the canvas it
replaces.
Martin | martin at
Gregorie | gregorie dot org
Old November 11th 18, 02:54 AM posted to rec.aviation.soaring
a presence there.
AMA Expo:
chutes.
replaces.
Martin | martin at
What Martin said..
Try this for a (relatively) cheap 'chute. Bite the bullet and buy one Tost small winch 'chute and take it to your local rigger and ask how much to make a replica. There's a good chance that will be much less than what you paid for the 1st 'chute.
Old November 11th 18, 03:27 AM posted to rec.aviation.soaring
AS
a presence there.
AMA Expo:
chutes.
replaces.
Martin | martin at
What Martin said..
We have been using this type of military surplus chute for years now and they hold up very well. The trick is to 'fly' the chute reasonably close to the winch and then drop it but not drag it over the ground.
https://www.ebay.com/itm/NEW-UNISSUE...-1:rk:140:pf:0
Unfortunately, they have become harder and harder to find. Fortunately, I bought a few at a surplus store in TX, when they still had them. ;-)
Uli
'AS'
Old November 11th 18, 10:18 PM posted to rec.aviation.soaring
Frank Whiteley
a presence there.
AMA Expo:
chutes.
replaces.
Martin | martin at
What Martin said..
Uli
'AS'
The orange chutes have become rare to non-existent, but work very well if you can source them. The similar option looks reasonable. Might have to order one to see if it's useful.
Frank Whiteley
Old November 11th 18, 04:26 PM posted to rec.aviation.soaring
Dan Marotta
That's less expensive than a drag chute used in drag racing.Â* And for
our Brit friends, drag racing is not men in dresses and high heels
running a foot race... :-D
a presence there.
AMA Expo:
chutes.
replaces.
Martin | martin at
What Martin said..
Dan, 5J
Old November 11th 18, 04:42 PM posted to rec.aviation.soaring
Dan Marotta
Credit to Monty Python...
has
a presence there.
AMA Expo:
chutes.
keeps
winch
replaces.
MartinÂ*Â*Â* | martin at
GregorieÂ* | gregorie dot org
What Martin said..
Try this for a (relatively) cheap 'chute.Â* Bite the bullet and buy
how much to make a replica.Â* There's a good chance that will be much
Dan, 5J
Old November 11th 18, 05:07 PM posted to rec.aviation.soaring
You talking RuPaul....?!?!
LOL......
If talking to Brits, be careful of fags or faggots......quite a bit different in the US than "Queens English"......;-)
[cigarettes or meatballs....in order.....]
Parachute use in single seat gliders [email protected] Soaring 13 May 20th 16 04:14 PM
Anyone got a source... Jay Honeck[_2_] Home Built 12 November 17th 09 01:47 AM
SH-2F Seasprite from HSL-31 winches up its sonar Dave Kearton Aviation Photos 17 March 6th 07 04:10 AM
Source Mu Metal USA HL Falbaum Soaring 6 April 12th 06 03:53 PM
Winches (was Aerotow with Diesel engine? [email protected] Soaring 20 October 30th 04 05:27 AM
