water balast?
Old February 22nd 05, 11:51 AM
JohnWN in Burke, VA
Default water balast?
I have only flown as a passenger once in a sailplane, and thus, will ask the
obvious question. Is water blast used in temperatures where it is likely to
freeze? If so, what is done to prevent this?
Thanks ...john
Old February 22nd 05, 12:17 PM
Ken Kochanski (KK)
Ridge flights in the spring can expose the sailplane to near freezing
conditions at ridge height ... or definitely during periods when you
have to climb as the temp drops quickly as altitude gained.
Many pilots add some anti-freeze if they expect to be in sub-freezing
conditions for any lenght of time. This is not as extreme as
automotive protection ... a light amount of antifreze (I add windshield
washer fluid to wing water and use 100% in the tail tank as the volume
is smaller and will freeze more quickly.) to depresses the freezing
point by 10 degress or so ... let say down to 20F. Sailplanes have no
heat ... so these temps can get pretty uncomfortable quickly ... i.e.
we don't stay there. :-) BTW, we have thermometers to measure outside
air temp.
So, we typically don't fly in extended freezing conditions with H20 ...
but may be in sub 32F conditions for a short time anticipatieng we will
be out quickly ... and will often add antifreeze if we expect some type
of possible longer exposure ... even if not extended.
KK
ask the
likely to
Thanks ...john
Old February 22nd 05, 12:16 PM
Mal.com
Not a good idea to have it freeze you could blow the wing up.
Fly with out water.
More likely to freeze in winter.
Flight level 235 in August was -30oC
http://www.mals.net/bunyan04/pages/Picture%20013.htm the grease starts to
freeze.
Mal
www.mals.net
"JohnWN in Burke, VA" wrote in message
news:41FSd.689$2s.199@lakeread06...
the obvious question. Is water blast used in temperatures where it is
likely to freeze? If so, what is done to prevent this?
Thanks ...john
Old February 22nd 05, 02:00 PM
Most manufactures recommend dumping once the temperature lowers to 4
degrees C. As noted by Ken, we have strategies for using water in
sub-freezing conditions, but there is some risk associated. These
include accumulation of ice on the tail due to leaks or freeezing shut
of the dump valves.
Using the 4C mark guarantees avoiding both problems. But as in all
things, good judgement and forethought can expand the envelope a
little. One simply has to understand and effectively manage the
increased risk.
Induction System Water Problem Mike Spera Owning 1 January 30th 05 05:29 AM
Water, water, everywhere, but none for thirsty wings.... Chris OCallaghan Soaring 0 November 21st 04 03:14 PM
Questions regarding Air/Oil Separators Doodybutch Owning 6 April 20th 04 05:56 PM
Water Cooled Jet Engines: a possibillity then and now? The Enlightenment Military Aviation 3 December 18th 03 09:41 AM
C-17s as water bombers Ross Oliver Piloting 11 November 12th 03 02:22 AM
