FAA broadcast about TEB..
Old March 12th 05, 12:21 AM
Dave S
Default FAA broadcast about TEB..
I got the following from the FAA on their email broadcast.. its normally
the way they send out info about local safety seminars.. Interesting how
they are addressing a local traffic issue on a national level.. prudent?
or overkill?
Dave
Teterboro Airport Operations & The Teterboro 5 Departure
ALTITUDE DEVIATIONS DURING IFR DEPATURE PROCEDURES AT TETERBORO AIRPORT
ARE CAUSING POTENTIAL MID AIR COLLISIONS. IF YOU PLAN TO OPERATE INTO OR
OUT OF THE TETERBORO AIRPORT (KTEB), PLEASE UNDERSTAND, AND COMPLY WITH
THE TETERBORO FIVE DEPARTURE PROCEDURE ALTITUDES. There have been many
altitude deviations by pilots flying this procedure, and they are
causing. POTENTIAL MID AIR COLLISIONS WITH NEWARK INTERNATIONAL AIRPORT
ARRIVALS. For complete information, click on the following link:
http://www.faasafety.gov/SPANS/event...of_TEB_5-2.pdf
Completing a flight or maintenance action safely is a complex process.
Use the materials at FAASafey.gov to sharpen and maintain your skills.
Old March 12th 05, 12:26 AM
Lakeview Bill
Uhhh...
Airplanes can fly a long way. A lot of them can fly all of the way to
Teterboro.
And it is probably the people who fly a long way to Teterboro who are
causing most of the problems, not those who are based there.
Very prudent indeed...
"Dave S" wrote in message
ink.net...
or overkill?
Dave
Old March 12th 05, 01:28 AM
Mitty
They have sent local mail out on the national list by accident before. Maybe
this time too. I got it in Minnesota.
On 3/11/05 5:21 PM, Dave S wrote the following:
or overkill?
Dave
Old March 12th 05, 01:17 PM
or overkill?
Not overkill at all because of the nature of the operations at TEB. Jet
aircraft come and go nonstop to and from all parts of the country. Lots of
flights from the Los Angeles area everyday non-stop to TEB, for example.
Part of the problem, I suspect, is modern FMS/LNAV aircraft trying to fly a
ancient round-dial aircraft departure procedure, especially one that
includes an NDB crossing and an NDB bearing crossing.
Old March 12th 05, 04:09 PM
C J Campbell
"Lakeview Bill" wrote in message
m...
Uhhh...
Teterboro.
They use a departure procedure to fly to Teterboro? :-)
Old March 12th 05, 04:53 PM
Jose
or overkill?
If the problem is restricted to (mainly) TEB departures, this tells me
there is something wrong with the procedure. Yes, the pilots should fly
it correctly and should not blow altitudes and all, but the design of
the procedure makes it easy or difficult, and easy is better (all other
things being equal).
Our theater recently replaced the sound system with new equipment where
the buttons (play, fast forward, etc) are all in non-standard and
unexpected positions. It is =far= easier to make a mistake, and of
course they blame the sound guy (after all, the buttons are labelled).
But the problem (and the best solution) lies elsewhere.
Jose
Math is a game. The object of the game is to figure out the rules.
Old March 12th 05, 05:36 PM
Roy Smith
This is certainly one of the more complex procedures I've seen. It reads:
TAKE-OFF RUNWAY 19: Climb runway heading until leaving 800 feet, then turn
right heading 280^. Maintain 1500 feet until crossing the TEB R-250 and
passing TEB 4.5 DME, then climb and maintain 2000 feet (non-DME aircraft
maintain 1500 feet until crossing PNJ NDB 015^ bearing, then climb and
maintain 2000 feet.)
You're need to meet two restrictions at once (get past a radial and get
past a DME arc). And for those non-DME types who's ADF skills may be a bit
rusty, well, let's just say that I don't think I'd like to be working an
NDB bearing crossing problem while turning, climbing, and talking to
departure all at the same time.
This would be so much easier to fly if they invented an RNAV waypoint at
the right place and said: "Climb runway heading until leaving 800, then
climb to 1500 direct FUBAR. After crossing FUBAR, maintain 2000. They
could leave the old procedure in place for non-RNAV aircraft.
I think the other thing that makes the FAA so worked up about procedure
busts here is the proximity to Newark. The two airports are only 10 miles
apart, and departures off 19 are pointed almost directly at EWR. The
multiple "step-up" fixes are to keep you below the arrivals into EWR's 22L
& 22R. There are very few places where leveling off a few hundred feet
high on an initial climbout is so likely to result in a separation bust. I
can't imagine how often arrivals into EWR get TCAS alerts due to traffic
climbing out of TEB.
Red Bull Air Race broadcast live on the web! jvogel Piloting 0 August 11th 04 02:32 PM
Red Bull Air Race broadcast live on the web! jvogel Aerobatics 0 August 11th 04 02:28 PM
Capstone Scott Moore Instrument Flight Rules 18 May 29th 04 08:16 AM
Satellite Radio to broadcast weather data James M. Knox Owning 4 July 4th 03 07:30 PM
Satellite Radio to broadcast weather data Richard Kaplan Owning 2 July 4th 03 05:45 PM
