Requirement to fly Departure Procedures
Old March 25th 05, 02:30 PM
Default Requirement to fly Departure Procedures
The word on the street seems to be that with a departure clearance
from an uncontrolled airfield of "cleared on course" any ODP would not
need to be flown in VMC. . However, I'm not sure how the FAR quote
below, which also applies to Class C and B airspace, supports that.
Clearly, an ODP is established by the FAA. Anyone?
91.129 Operations in Class D airspace
(g) Departures. No person may operate an aircraft departing from an
airport except in compliance with the following:
(1) Each pilot must comply with any departure procedures established
for that airport by the FAA.
http://ecfr.gpoaccess.gov/cgi/t/tex...0.1.3.10.2.4.15
Perhaps this thread has been visited recently, and if so, I apologize.
Stan
Old March 25th 05, 03:58 PM
Roy Smith
That applies (as you said) to B, C, and D airspace. It says nothing about
E or G. I think the real answer is in the AIM, which says in section
5-2-6(c)(1) (http://www.faa.gov/ATpubs/AIM/Chap5/aim0502.html#5-2-6)
"Obstacle clearance responsibility also rests with the pilot when he/she
chooses to climb in visual conditions in lieu of flying a DP"
Basicly, if a DP/ODP/SID/nom d'jour is assigned, you have to fly it. If
none is assigned at an uncontrolled airport, and there is a DP published,
you have the option of either flying the DP or flying a departure of your
own choice by visual reference.
Old March 25th 05, 04:05 PM
Steven P. McNicoll
"Roy Smith" wrote in message
But what about uncontrolled fields in such airspace?
Old March 25th 05, 04:43 PM
Steven P. McNicoll
wrote in message ...
91.129 is not an IFR rule.
FAR 91.129 is a General rule, that means it applies to ALL operations.
That language applies to any departure
procedure established for noise abatement at an airport with an operating
control tower. Like a sign at the runway that says "Turn and fly over the
river southbound until leaving 2,300."
If that's true, then why does it appear under FAR 91.129(g) Departures and
not under FAR 91.129(h) Noise Abatement?
Old March 25th 05, 05:00 PM
Because the left-handed attorney didn't look over the work of the right-handed
attorney.
If you reasoning is correct, then all departures, instrument qualified or not,
would have to fly the IFR ODP.
Old March 25th 05, 05:08 PM
Steven P. McNicoll
right-handed
attorney.
not,
Yes, and all because the left-handed attorney didn't look over the work of
the right-handed attorney.
Old March 25th 05, 06:18 PM
Kris Kortokrax
Stan
According to the following legal interpretation, one is not required to fly
an instrument departure procedure.
Also, look at 91.129 (b) which allows the controller to authorize a
deviation from the requirements of 91.129.
It would seem to me that a clearance or instruction to proceed on course is
an authorization to deviate from a departure procedure.
In IMC, however, you may not want to deviate from the procedure.
Kris
FAA LEGAL INTERPRETATIONS - 1993
November 30, 1993
Dear Mr. McBride and Mr. Birdsong:
This is in response to your letter of June 30, 1993, in which you request an
interpretation of Section 91.129(f) of the Federal Aviation Regulations
(FAR) (14 CFR Section 91.129 (f)).
Section 91.129(f) states, in part, that no person may operate an aircraft
taking off from an airport with an operating control tower unless he
complies with any departure procedures established for that airport by the
Federal Aviation Administration (FAA). Instrument Flight Rules (IFR)
departure procedures are established to provide a safe and efficient route
from an airport to the minimum enroute altitude.
The FAA establishes IFR departure procedures in accordance with criteria set
forth in the United States Standard for Terminal Instrument Procedures
(TERPs). IFR departure procedures established under the TERPs are designed
to ensure terrain and obstacle clearance provided a pilot adheres to them.
In your letter, you ask whether a pilot must adhere to an IFR departure
procedure when cleared for takeoff at an airport with a published IFR
departure procedure. You specifically ask whether a pilot is required to
adhere to such a procedure under various operating conditions.
Under Section 91.113(b), when weather conditions permit, a pilot must
operate his aircraft so as to see and avoid other aircraft regardless of
whether the flight is conducted under Visual Flight Rules (VFR) or under
IFR. However, under Part 91, a pilot generally is not required to adhere to
a published IFR departure procedure. Under Instrument Meteorological
Conditions (IMC), a pilot should, but is not required to, follow an IFR
departure procedure. When outside of radar coverage, however, a pilot
remains responsible for terrain and obstacle clearance.
Furthermore, Section 91.123 provides that a pilot may not deviate from an
Air Traffic Control (ATC) clearance except in an emergency or unless an
amended clearance has been obtained. Accordingly, a pilot operating under
Part 91 must follow an IFR departure procedure when it is part of the
applicable ATC clearance.
Under Part 121 or Part 135, a pilot is required to follow any published IFR
departure procedure regardless of whether the flight is conducted under VMC
or under IMC.
If you have any further questions regarding this matter, please contact
Patricia R. Lane, Manager, Airspace and Air Traffic Law Branch.
Sincerely,
Donald P. Byrne
Assistant Chief Counsel
Regulations Division
Old March 25th 05, 07:37 PM
Note that is limited to IFR departures for Part 121 and 135 operators.
Stan
Kris
November 30, 1993
or under IMC.
Sincerely,
Donald P. Byrne
Old March 25th 05, 08:12 PM
Ron Rosenfeld
Stan
Various interpretations have taken that paragraph to apply to noise
abatement types of departure procedures.
Under Part 91, it is the pilot's option as to whether or not to fly an
UNassigned IFR ODP.
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 06:14 AM
Notes on NACO Obstacle Departure Procedures John Clonts Instrument Flight Rules 1 July 15th 04 11:20 PM
Agent86's List of Misconceptions about of FAA Procedures Zero for 15 Putz!!! copertopkiller Military Aviation 12 April 20th 04 03:21 AM
Agent86's List of Misconceptions about FAA Procedures Zero for 15 Putz!!! copertopkiller Military Aviation 9 April 18th 04 07:13 PM
Requirement to fly departure procedures [email protected] Instrument Flight Rules 77 October 15th 03 07:39 PM
