Commodious Rodent Entrance in Grob 103
Old June 14th 20, 03:28 AM posted to rec.aviation.soaring
George Haeh
Default Commodious Rodent Entrance in Grob 103
Last year we cleaned out and restored our club G-103.
For rodent proofing we:
* stuffed part of a stainless steel pot scrubber around the brake hose where it comes out of the gear well
* made a magnetic cover for the CG hook, and
* a diaper to fit over the bottom of the the fin and rudder junction
* left Fresh Cab mouse repellent in the cockpit over the winter
Doing the annual after Covid19 delay, we found abundant mouse droppings in several areas along with one dead and one live field mouse caught by the vacuum.
I had another look inside the gear well and discovered an open tube about an inch in diameter below and towards the center from the brake hose.
Inside that tube supports the brake reservoir. Said tube now has a stainless scrubber stuffed into both ends.
Perhaps the tube is there for the retraction mechanism of the earlier model.
Old June 14th 20, 03:33 AM posted to rec.aviation.soaring
Waveguru
One of the most effective ways to keep rodents out of your sailplanes is to stop eating any food in the glider. If people are eating in the glider they invariably drop crumbs which will attract rodents.
Boggs
Old June 14th 20, 03:07 PM posted to rec.aviation.soaring
Dan Marotta
I've seen gliders stored in a hangar with the wheels surrounded by sheet
metal walls.Â* Don't know how well that works.Â* I've also seen "mouse
paper", a super sticky paper, spread around the wheels to trap them.Â*
Might be worth a try.
Boggs
Dan, 5J
Old June 14th 20, 04:16 PM posted to rec.aviation.soaring
AS
Employing a couple of hangar-cats may hep. Did the trick in the hangar of a club I used to fly with in the NE.
Uli
'AS'
Old June 14th 20, 04:49 PM posted to rec.aviation.soaring
Roy B.
Old fashioned method that still works:
Partially fill a couple of old socks with regular naphthalene mothballs and put the socks inside the cockpit and wings. Mice hate the smell and go away. Of course, you might too . . .
Roy
Old June 15th 20, 01:43 AM posted to rec.aviation.soaring
Gotta be the traditional naphthalene but it does work. Only thing I’ve found that does
Old June 15th 20, 02:14 PM posted to rec.aviation.soaring
Nick Kennedy[_3_]
This could go Into Story Time:
I'm in the towplane; were giving rides in our mouse laden L-13.
The pilot is strapping in the passenger in the front and I'm parked in the tug in front of the Blanik at a 45 degree angle, watching the scene, when a mouse drops out of the front of the glider to the asphalt , runs underneath the ship to the back and jumps back in. They canopy's are closed and locked and off we all go. I was cracking up knowing there was a mouse along for the ride.
We also used mothballs tied up in pantyhose and put around the mainwheel and tailwheel, this helped for sure but the mouse battle was unending. A electric rodent chaser based on high frequency noise also seemed to help, but you need power for that.
Nick
T
Old June 15th 20, 04:35 PM posted to rec.aviation.soaring
Waveguru
Sounds like a set up for another tow pilot fatality.....
Boggs
Old June 15th 20, 06:31 PM posted to rec.aviation.soaring
Hightime
Walk the plank in a 5 gallon pail works great
The new design means you can keep the lid on unlike the old design , it helps to keep dogs and smell and sensitive public eyes from seeing The dead mice
I use 50/50 to keep the mice fresh , then bury them
Just build a small walkway up to the opening in the pail , I don’t even bait the walkway anymore since mice go everywhere anyway , one after the other walks the plank
https://www.ebay.ca/itm/132445369253
Old June 19th 20, 05:35 AM posted to rec.aviation.soaring
2G
The Rolling Log mouse trap works great and is self-resettable:
https://www.youtube.com/watch?v=6SIlYiiCGLI
Tom
Rodent proofing CG Hook George Haeh Soaring 14 March 7th 19 07:21 PM
Rodent Deterrent? rlovinggood Soaring 20 January 7th 08 05:22 AM
Commodious Sailplane? Jim[_6_] Soaring 19 October 11th 06 04:16 AM
Commodious Sailplane? James Hamilton Soaring 0 October 9th 06 09:37 AM
commodious sailplane Andy Davey Soaring 0 October 8th 06 08:02 PM
