Mags
Old April 18th 05, 05:09 AM
tony roberts
Default Mags
Hi
I'm running in my overhauled engine - 4 hrs - all a full rich.
Today I landed at a nearby airport and when I did the run-up to return
home the left mag gave a 400 rpm drop. I tried it again and got another
400 pm drop.
Third time I tried it I had no left mag at all - drop to cut-off - same
4th time.
Shut down - check all connections - everything looked good - no loose
wires etc.
Today for the first time I used my new carb-temp guage and as it was
reading 30F I added a small amout of carb heat to bring it to 37F. On
reflection I should have leaned slightly to allow for the extra richness
from the cab heat but I didn't.
I went back to the aircraft and it stated OK. I ran it leaned for a
couple of minutes, went full rich to 1700 rpm and did mag checks - both
were good. I did it 5 times, and departed for home. Aircraft ran great,
after landing I did 3 more mag checks and they were all good.
Question - Could fouling really have totally shut down my left mag?
Thanks for reading,
Tony
Tony Roberts
PP-ASEL
VFR OTT
Night
Cessna 172H C-GICE
Old April 18th 05, 06:14 AM
George Patterson
Highly unlikely. You're talking about fouling 4 plugs, two on the top and two on
the bottom. Top plugs rarely foul.
George Patterson
There's plenty of room for all of God's creatures. Right next to the
mashed potatoes.
Old April 18th 05, 05:56 PM
My O-200 Continental has the left mag firing all the lower plugs and
the right mag firing the upper plugs. What George says is true of
Lycoming engines where the mags fire 2 and 2. If indeed, the left mag
is firing the lower plugs, it could easily exhibit your problem. Pull
the lower plugs and take a look.
Tim (C-150M)
Old April 19th 05, 04:20 PM
CriticalMass
I don't understand why you would want to operate the engine without
leaning. No recommendation I've ever read about post-overhaul break-in
ever included anything like that.
4th time.
IMO, an indication of something not right in the mag. It bears watching.
wires etc.
So, an intermittent problem.
OAT wouldn't have any bearing on the issue with the mag. Here in south
central USA, we get outside temps over 100 degrees F in summertime, and
mag drops aren't noticeably different than in winter with temps in the
30s-40s.
Answer is no - the mag has no way to know what's going on with the
plugs. **Fouled plugs** from over-rich mixture can, and often do,
result in bad run-ups and mag-checks, but I'm more inclined to suspect
there's something going on in the mag. A look at the plugs for that mag
would be helpful in making that determination.
Old April 19th 05, 11:05 PM
Dan Luke
Well, you do want to run the engine at high power settings to seat the rings
and you don't want to get the cylinders too hot lest they glaze, so running
rich for break-in is a pretty common precaution against the latter.
Dan
C-172RG at BFM
Old April 20th 05, 05:30 AM
Matt Barrow
"Dan Luke" wrote in message
rings
running
Um...leaner is cooler, Dan! 50 LOP is about a hot as you can get an engine
without milting it down into slag.
Old April 20th 05, 06:40 AM
tony roberts
But Matt, you are taking about rich or lean of PEAK.
But we are talking about FULL rich - as in mixture control full in.
That is waaay cooler than getting near peak - I monitor all 6 CHT's and
EGT's on my analyzer. At full rich, lean & temp goes up, richen & it
comes down. Add carb heat and it comes down more.
I also have a digital oil temp monitor - and the oil temp also goes up
as I lean and down as I reichen.
You can go over to lean of peak and it can be a very efficient thing to
do - but you had better be fuel injected with GAMI injectors, or therte
is a good chance you will melt it into slag as you suggest.
Thanks to everyone for their responses on this - I appreciate them
Tony
Tony Roberts
PP-ASEL
VFR OTT
Night
Cessna 172H C-GICE
rings
running
Tony Roberts
PP-ASEL
VFR OTT
Night
Cessna 172H C-GICE
Old April 20th 05, 01:28 PM
Dan Luke
engine
No. Highest power, and thus greatest heat, occurs ROP. Maybe that is
what you meant to say.
I routinely run my engine 50 LOP in cruise; the CHT's stay below 380
deg. How could I get it hot enough to "melt it down into slag?"
Anyhow, "leaner is cooler" is so general as to be useless as a
guideline. It is true that cylinders will run cooler at some point LOP
than they will at some point ROP, but most carbureted engines cannot run
LOP because of poor fuel distribution. The only option in that case, if
one wishes to be sure the cylinders stay cool during break-in, is to run
well rich-of-peak.
Dan
C172RG at BFM
Old April 20th 05, 05:23 PM
Matt Barrow
engine
(contradictions in back-to-back sentences)
Yup...(If leaner is cooler then LOP is cooler) that's what happens when I
post five minutes before bedtime :~( (contradictions in back-to-back
sentences)
I meant ROP (especially 50 ROP) is the worst setting you can use, not only
in terms of heat but cylinder pressure as well.
( Never mind!! )
Does anyone have Kitplanes Mag's from 1986? Nunya Home Built 10 June 21st 11 08:22 AM
VW1834 and Slick 4001 Mags M J Veary Home Built 4 March 5th 05 12:23 AM
FA: Slick Mags (used) 600 series with harness BFC Aviation Marketplace 0 June 24th 04 05:21 PM
Two Mags from Florida Larry Smith Home Built 7 October 25th 03 09:47 AM
Av mags and sims.... Don Parker Simulators 7 August 11th 03 06:48 PM
