Why no stepdown fix in GPS?
Old June 25th 05, 09:55 PM
Roy Smith
Default Why no stepdown fix in GPS?
I flew the KFWN VOR or GPS-A (http://204.108.4.16/d-tpp/0506/05412VGA.PDF)
this morning with a CNX-80. Annoyingly, ANKLE (the stepdown fix) is not in
the database. You get SAX-MAGLV. It seems like SAX-ANKLE-MAGLV would
make a lot more sense. Is the some reason it's left out of the database?
Old June 26th 05, 12:57 AM
It's an overlay, so someone at Jeppesen made a coding judgment to treat it as
an ATD stepdown fix. I believe that is the protocol agreed upon for GPS final
approach segment stepdowns, but having said that, I suspect they are treated
both ways.
Old June 26th 05, 01:01 AM
Roy Smith
What's "ATD"?
Old June 26th 05, 02:38 PM
What's "ATD"?
It's in the AIM (many times ;-) "Along track distance
From AIM 1-1-19.13:
13. Unnamed stepdown fixes in the final approach segment will not be coded in the
waypoint sequence of the aircraft's navigation database and must be identified
using ATD. Stepdown fixes in the final approach segment of RNAV (GPS) approaches
are being named, in addition to being identified by ATD. However, since most GPS
avionics do not accommodate waypoints between the FAF and MAP, even when the
waypoint is named, the waypoints for these stepdown fixes may not appear in the
sequence of waypoints in the navigation database. Pilots must continue to identify
these stepdown fixes using ATD.
Old June 27th 05, 11:56 PM
Is it part of FAA's move to CANPA? I found it easier to read out
distances then fixes when doing CANPA on my FS2004 with
JeppView/FliteDeck connected on another computer, but not in real plane
yet.
Old July 1st 05, 02:14 AM
Roy,
No comments on my helpful answer?
What's "ATD"?
Old July 1st 05, 02:25 AM
Roy Smith
In article , wrote:
Roy,
Um, well, it was helpful, thanks.
descent below minimums hsm Instrument Flight Rules 82 January 11th 05 06:33 PM
GPS approaches with VNAV vertical guidance Doug Instrument Flight Rules 18 November 2nd 04 10:36 PM
Yet another "Radar Required" question. Roy Smith Instrument Flight Rules 14 April 27th 04 05:07 PM
Crossing a stepdown fix high David Brooks Instrument Flight Rules 51 October 22nd 03 07:25 AM
