Extra Kollsman Altimeter Pointers
Old July 3rd 05, 04:52 PM
Default Extra Kollsman Altimeter Pointers
I have an old Square D Kollsman 3 pointer altimeter that I think it's
about 50 or more years old and seems to be in working condition. The
body is about 2 13/16 diameter. The label on the back says part no.
371K-05
The three altitude pointers give the usual altitude readout. The little
Kollsman barometer window works and I know how to synchronize a known
altitude with the known barometer pressure by removing the little screw
and pulling the Kollsman knob out for the 'calibration'.
Now here's my question. There are two extra little visible pointers on
this altimeter that both rotate around concentric circles centered on
the instrument face. What are these pointers for. One is on the outer
circumference of the dial and the other one is on a smaller inner
circle with a radius of about 1 inch. Both pointers rotate when the
Kollsman knob is turned. They do NOT respond to air pressure changes.
The outer one moves at the same rate as the hundreds altimeter pointer
when the knob is turned. The inner pointer increments 100 feet when the
outer pointer makes one complete revolution around the face.
What are these "extra" pointers for???? They seem to serve no other
purpose than measuring the rotation of the Kollsman knob.
Dennis
Old July 3rd 05, 05:20 PM
Jose
What do they indicate at 29.92? How fast do they move (if you take them
to indicate an altitude?)
Jose
You may not get what you pay for, but you sure as hell pay for what you get.
Old July 3rd 05, 07:18 PM
them
If I set the Kollsman to 29.92, the little pointers indicate 1,740 ft.
They only move when I turn the Kollsman knob and the pointers turn in
sync at the same rate as the hundreds and thousands regular pointer
hands move. The pointers do NOT move with actual air pressure changes,
only when I manually rotate the Kollsman knob.
Old July 3rd 05, 10:04 PM
snj-5
I have one of those in my airplane, but only (1) extra pointer
on the circumference. I recently had the unit overhauled and
the avionics shop guy said he was told it was a Navy thing, and
the little pointer was an aid in determining just how far off
of 29.92 (in feet) one was when the local barometric pressure
was set.
I just ignore the feature....
Bela P. Havasreti
371K-05
Dennis
Old July 4th 05, 04:01 PM
Mitty,
When I set the Kollsman window to 29.92 today, the main pointers show
about -200 feet (which is correct as the barometer now is actually
30.15). And as I mentioned, at a Kollsman setting of 29.92, these
extra pointers show 1,740 feet regardless of the actual barometric
pressure.
Altimeter settings: QNH versus QFE [email protected] Soaring 28 June 6th 05 01:26 PM
ATC Altimeter Settings O. Sami Saydjari Instrument Flight Rules 81 April 11th 05 09:07 PM
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 10:14 PM
Local altimeter at BFM Dan Luke Instrument Flight Rules 3 June 15th 04 03:01 PM
Why not use the F-22 to replace the F/A-18 and F-14? Guy Alcala Military Aviation 265 March 7th 04 10:28 AM
