BFR.. define "rated".
Old September 22nd 05, 12:09 AM
Dave S
Default BFR.. define "rated".
Pinging the group for an answer here.
Scenario: Up for flight review, elect to have instruction in a
taildragger for the purpose of the flight review. Have a PP-ASEL, but do
NOT have a one time endorsement in tailwheel aircraft that permits one
to be PIC.
The regs say you must take the flight review in an aircraft that one is
"rated" for. Does rated apply to "category and class" or is there also
the need to meet tailwheel, complex or high performance as well (when
applicable)?
The part 61 FAQ's dont address the reviewee needing to have a tailwheel
endorsement specifically, only the reviewer/CFI.
Dave
Old September 22nd 05, 12:19 AM
Brian
I believe that category and class is good enough for the definition of
"Rated" but I would have to do a bit of research to give you a 100% for
sure answer.
On the other hand it really shouldn't matter. It will likely take you
about 5 hours to get the Tailwheel endorsement. Most any instructor
would at the end of the 5 hours sign you off for a FR as long as you
also do the 1 hour of ground instruction required as well. Your time
might look like 4 hours of Dual in a tailwheel aircraft. 1 hour flight
training per FAR 61.56. You might have to a bit more for the FR than
just what is required for the tailwheel endorsement but it should be
less than doing them separately.
Brian
CFIIG/ASEL
Old September 22nd 05, 12:24 AM
Robert M. Gary
Rating are things printed on your ticket. See FAR 1.
-Robert, CFI
Old September 22nd 05, 12:26 AM
RST Engineering
My understanding is that you must have all the necessary qualifications in
that aircraft to act as PIC, which would include tailwheel, complex,
high-performance, etc.
"rated" for. Does rated apply to "category and class" or is there also the
applicable)?
Old September 22nd 05, 12:33 AM
Michael
Your understanding is incorrect.
Category, class, and type if required.
In this case, airplane, single engine land
Michael
Old September 22nd 05, 12:39 AM
George Patterson
applicable)?
You need to be rated in category and class. Keep in mind, though, that somebody
needs to be acting PIC. If you don't have the tailwheel signoff, the CFI has to
have it.
George Patterson
Give a person a fish and you feed him for a day; teach a person to
use the Internet and he won't bother you for weeks.
Old September 22nd 05, 01:04 AM
Larry Dighera
On Wed, 21 Sep 2005 22:09:31 GMT, Dave S
wrote in et::
"rated" for.
http://tinyurl.com/b938n
Rating means a statement that, as a part of a certificate, sets
forth special conditions, privileges, or limitations.
Old September 22nd 05, 01:13 AM
Sylvain
that was my reasoning too; i.e., the original poster
is fine (tailwheel, high-performance, complex, high-
altitude) are endorsements, not ratings.
--Sylvain
Old September 22nd 05, 01:18 AM
RST Engineering
And you all agree that "rated" and "rating" mean the same thing?
"Larry Dighera" wrote in message
wrote in et::
"rated" for.
Old September 22nd 05, 01:46 AM
Viperdoc
So, if you have a SEL, MEL, and seaplane ratings do you have to do a BFR in
three different planes?
Airports Rated Critical Unsatisfactory: Given Black Star Rating Michael Ravnitzky Piloting 0 February 3rd 05 04:34 AM
Define penetration. Bruce Greeff Soaring 27 February 7th 04 04:41 PM
Aerobatic Rated? c hinds Soaring 0 December 17th 03 06:15 PM
Aircraft engine certification FAR's Corky Scott Home Built 4 July 25th 03 07:46 PM
Enlisted pilots John Randolph Naval Aviation 41 July 21st 03 03:11 PM
