Question about Approach Plates
Old October 24th 05, 02:16 AM
Russ MacDonald
Default Question about Approach Plates
One of my students asked me a question the other day that I have been unable
to answer.
Many instrument approaches are labeled with a letter following the primary
name and the letter indicates that the final approach course is not lined up
(beyond 30 degrees) with any runway, and that a circling approach is
required. For example: VOR-A.
That said, what is the difference between VOR-A, VOR-B, VOR-C, etc? Does
the letter have any additional significance? Why, at some airports is there
a VOR-B or VOR-C but no VOR-A? Is it because there used to be a VOR-A and
it was decommissioned?
Russ MacDonald, CFII
Old October 24th 05, 02:53 AM
Stan Prevost
The "A " suffix is applied to the first approach generated for that city
name. "B" is for the second approach for that city name. It is not by
airport, but by city name.
"Russ MacDonald" wrote in message
news:tJV6f.11984$gF4.4699@trnddc07...
unable to answer.
up (beyond 30 degrees) with any runway, and that a circling approach is
there a VOR-B or VOR-C but no VOR-A? Is it because there used to be a
VOR-A and it was decommissioned?
Old October 24th 05, 03:06 AM
Roy Smith
In article tJV6f.11984$gF4.4699@trnddc07,
to answer.
There is no significance other than the order the approaches were first
published. They start at A for the first circling approach at an airport,
and work their way through the alphabet. Some airports have a bunch of
them; LGA has an LDA-A, VOR/DME-E, VOR-F, VOR-DME/G, and VOR-DME/H.
Presumably at some time there were B, C, and D approaches which have since
been revoked.
BTW, it's not just mis-alignment between the FAC and the runway. An
approach will also not get straight-in minimums if the descent profile is
too steep (IIRC, 400 ft/nm). Compare and contrast, for example, the VOR-A
and the VOR/DME-24 at POU. Exactly the same FAC, but the DME approach gets
you a couple hundred feet lower at the FAF, so it qualifies for straight-in.
Old October 24th 05, 03:22 AM
Correct, except for CAT D, the limit is 350 feet per mile. (Used to be 400 like
A,B, and C.)
Old October 24th 05, 04:09 AM
Steven P. McNicoll
unable to answer.
It's not just the alignment of the FAC, if the approach gradient is too
steep or the runway is indistinct there will be no straight-in minima.
The alphabetical suffix for circling procedures is not duplicated at
airports with identical city names within the same state.
Old October 25th 05, 01:41 AM
Randy
OK maybe somebody can answer this one...on the NOAA plates near the top
of the page there is a little three or four digit number that
corresponds to the airport...anybody know where I can find a list of
airport names that match the numbers?
GPS approach question Matt Whiting Instrument Flight Rules 30 August 29th 08 04:54 AM
Contact approach question Paul Tomblin Instrument Flight Rules 114 January 31st 05 07:40 PM
Approach Plates on PDA (PIREP) Stan Prevost Instrument Flight Rules 10 December 18th 04 05:21 AM
"Cleared Straight-In Runway X; Report Y Miles Final" Jim Cummiskey Piloting 86 August 16th 04 07:23 PM
Where is the FAF on the GPS 23 approach to KUCP? Richard Kaplan Instrument Flight Rules 36 April 16th 04 01:41 PM
