Tri-pacer Headliner
Old December 7th 05, 09:26 PM posted to rec.aviation.homebuilt
Default Tri-pacer Headliner
Hi groupe.
Is it possible to install a new headliner in a Tripacer with the cover
installed? I have a chance to buy a Tripacer that has a bad headliner.
Thanks........Joe
Old December 9th 05, 02:51 AM posted to rec.aviation.homebuilt
Yes
oldcoot wrote:
Hi groupe.
Thanks........Joe
Old December 16th 05, 10:33 AM posted to rec.aviation.homebuilt
It's very straightforward
$284 from Airtex http://www.airtexinteriors.com/catalogue/headliners.htm
You do this yourself as a pilot/owner under part 43.100 (11)
(11) Repairing upholstery and decorative furnishings of the cabin, cockpit,
or balloon basket interior when the repairing does not require disassembly
of any primary structure or operating system or interfere with an operating
system or affect the primary structure of the aircraft.
http://www.piperowner.com/maintenance.htm
If it has an O-290-D or D-2, watch out for thrashed lifter faces and rounded
cam lobes. Also, check the lower rear corner of the back door frame for
corrosion. A sure tip-off is if the back door consistently pops open on
landing. :-)
- Russ
news
Yes
oldcoot wrote:
Hi groupe.
Thanks........Joe
Headliner replacement Jim Burns Owning 6 May 19th 05 03:28 PM
C175A Headliner wanted Clay Owning 0 June 11th 04 08:14 PM
Piper headliner (was: simple and cheap tricks for your plane) Prime Owning 10 February 10th 04 05:05 PM
Piper Pacer for sale GASSITT Aviation Marketplace 0 January 9th 04 01:53 PM
Piper Pacer for sale GASSITT Aviation Marketplace 4 December 27th 03 12:42 AM
