Newbie holding questions
Old January 3rd 06, 11:01 PM posted to rec.aviation.ifr
Default Newbie holding questions
I am getting ready to start IFR training next week, and there are a
couple of questions regarding holding that I have been pondering.
(Searched through here already, but couldn't find the answers...at
least spelled out for me
When being assigned a hold, will ATC usually assign an altitude as
well? None of the samples I've seen in the FAA text or the AIM mention
an altitude in a clearance, and it made me wonder what happens when a
large volume of aircraft are holding at a busy airport waiting to land.
Do they "stack 'em and rack 'em" (like it looked the two times I've
flown into LHR), or do they have them hold all over the place (which I
observed on the BOS Airport Monitor a few weeks ago when that snowstorm
rolled through.)
Secondly, what happens there is a holding pattern used to enter an
approach to landing, and there are multiple aircraft landing? For
example, if there were several planes flying into Charlottesville (CHO)
from the east (GVE VOR, 17 nm), wouldn't everyone be entering the
holding pattern at 3300', thus creating a collision hazard? Or would
ATC only clear one aircraft at a time for the approach? Which doesn't
seem to do much for volume, but normally isn't an issue at a place like
CHO unless there is a football game....
Thanks in advance.
JohnK
PP-ASEL, IA student
Old January 3rd 06, 11:07 PM posted to rec.aviation.ifr
well?
In the Northeast US, I always hear altitude included in the holding
instruction.
At airports without radar coverage for the approach, only one aircraft will
be cleared for the published approach at a time. Other aircraft inbound
will be placed in a hold well outside of the approach until the aircraft on
approach cancels IFR, either in the air or on the ground.
At airports that have radar coverage on the approach (controlled or
uncontrolled) aircraft are simply vectored to the final approach course and
any published course reversals are bypassed.
Peter
Old January 3rd 06, 11:43 PM posted to rec.aviation.ifr
well?
If you're IFR, you *always* have an altitude assignment. Sometimes
it's a single altitude (maintain 3000), sometimes it's a limit (at or
above 4000). If a new altitude is not explicitly issued along with
the holding instructions, you last assigned altitude still applies.
what happens when a large volume of aircraft are holding at a busy
A lot of fuel gets wasted :-)
rolled through.)
In theory, they could have multiple aircraft holding at the same fix
at different altitudes. The one on the bottom is cleared to land, the
ones above get cleared down to lower altitudes, and new arrivals get
thrown onto the top of the stack. In practice, that never happens any
more. Flow control procedures at busy airports are supposed to ensure
that flights don't get cleared for takeoff until a slot is available
for them at their destination. Still, **** happens and sometimes you
end up with more flights arriving at once than can land, so you gotta
do something with them. Delaying vectors are more common than holding
stacks.
Virtually all real IFR traffic these days is given vectors to final.
None of this holding at the IAF **** unless you're in training, or out
in the boonies somewhere and there's no radar coverage.
Old January 3rd 06, 11:52 PM posted to rec.aviation.ifr
stacks.
Which strategy ATC chooses to use to slow approaching aircraft is probably
related to location, rather than the type.
For aircraft approaching NY or Boston airports, I have found that holds are
more common than delaying vectors when the weather really falls apart.
Peter
Old January 4th 06, 05:26 AM posted to rec.aviation.ifr
"Peter R." wrote in message
well?
instruction.
will
on
and
Peter
Makes sense, thanks Peter!
John K
Old January 4th 06, 03:53 PM posted to rec.aviation.ifr
At some locations timed approaches permit more than one approach at a
time, provided the holding pattern meets criteria and the missed
approach does not conflict with the inbound tracks.
Timed approaches were once used a lot, then over time diminished in
their use, and now they are on the increase again.
Old January 4th 06, 03:57 PM posted to rec.aviation.ifr
Thanks, Tim.
What are some example of airports where timed approaches are in use?
Peter
Old January 4th 06, 11:10 PM posted to rec.aviation.ifr
Is there any airport that uses timed approaches? I though this was FAA
legacy stuff. Could be useful during high traffic fly-ins if there is
no radar though I guess.
Old January 5th 06, 04:18 AM posted to rec.aviation.ifr
"JohnK" wrote in message
well?
No, an altitude is not specifically part of a holding instruction. There'd
be no need to issue an altitude if you're to hold at the currently assigned
altitude.
rolled through.)
They may do both and also employ other floe control measures.
At CHO they will be radar sequenced for the approach, football game or not.
Old January 5th 06, 04:21 AM posted to rec.aviation.ifr
An EFC should always be part of a hold clearance, if they
forget, ask.
James H. Macklin
ATP,CFI,A&P
"Steven P. McNicoll" wrote in
message
ink.net...
there are a
pondering.
answers...at
altitude as
| well?
currently assigned
| altitude.
mention
happens when a
waiting to land.
times I've
place (which I
that snowstorm
| rolled through.)
measures.
to enter an
landing? For
entering the
hazard? Or would
Which doesn't
at a place like
Questions from a newbie. Andrew Tubbiolo Home Built 9 September 14th 04 02:40 AM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 September 2nd 04 06:15 AM
Newbie with questions... Mike \(Remove X's to reply\) Piloting 10 February 14th 04 02:16 AM
Newbie questions Rail / Ejector launchers AL Military Aviation 19 November 14th 03 08:47 PM
Basic Stupid Newbie Questions... John Penta Military Aviation 5 September 19th 03 06:23 PM
