FAR 91.171 interpretation
Old September 16th 03, 02:24 AM
James L. Freeman
Default FAR 91.171 interpretation
What is the point of the phrase "at the airport of intended departure"
in FAR 91.171(b)(1)?
Interpreted literally, it would mean that while the VOR check done
with a VOT is good for 30 days, it is only valid for departures from
the airport where it was done. That makes no sense. Any other
interpretation that I can think of would be the same with or without
that phrase. What were "they" thinking?
Old September 16th 03, 04:08 PM
Ron Natalie
"James L. Freeman" wrote in message om...
I always contended that it means you can't do the VOR check and
then either:
1. Have an uninteded departure.
2. Move the aircraft to some other airport before departure.
I think it's just fluff. The intent of the phrase is the same as if the
phrase wasn't ther.
Old September 17th 03, 12:37 AM
James Blakely
And if you have an unintended departure, you have bigger problems than a
current VOR check.
m...
om...
then either:
phrase wasn't ther.
Old September 17th 03, 02:59 AM
Mike Granby
of intended departure" in FAR 91.171(b)(1)?
Well, how about this? The identity of the airport cannot be the issue,
because departure is not previously referenced in the regulation (ie. it
doesn't start with "no person may depart...") and because, absent this more
specific definition, any airport at which you land must be an airport of
intended departure, or you'd never leave there! In other words, it doesn't
matter which airport it is relative to the flight. Therefore, the key must
be the fact that you are at the airport where the VOT or check point is
located, and that you are still on the ground. If you remove the phrase from
(b)(1) it looks to me like it would then allow you to circle around an
airport with a VOT, and test your receiver from the air. With the phrase
included, this is not permitted. The argument is a little weaker for (b)(2),
but again, without the phrase, you could (just about!) over-fly the
designated check-point rather than be on the ground.
Mike Granby, PP-ASEL,IA
Warrior N44578
http://www.mikeg.net/plane
Old September 17th 03, 05:10 PM
Ray Andraka
Perhaps it is to prevent you from using a weak VOT signal from a nearby
airport. Can't think of any particular airports, but say your small airport or
private strip is located within reception range of the VOT at a nearby big
airport, this wording would not allow you to use the signal from that VOT (which
is not on the airport of intended departure).
Warrior N44578
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
Old September 17th 03, 07:47 PM
Mike Granby
weak VOT signal from a nearby airport.
Good point. The key is that you have to be at the airport where the VOT or
checkpoint is located.
Warrior N44578
Old September 20th 03, 07:40 PM
John Harper
I just got round to looking this one up, and I have a question... 91.171(b)
is clear about "airport of intended departure". But 91.171(c) says that if
you have two VOR receivers (which I guess any serious IFR airplane does)
then you can check them against each other IN PLACE OF ... (b). It
doesn't say anything about airports of intended departure, or VOTs,
or complicated airborne procedures.
I would interpret this to read that if I have a decent VOR signal on the
ground at an airport (without a designated checkpoint) - which I do
at my home airport - then a simple cross-check is OK for 91.171.
(And for sanity's sake checked also against the GPS, although of course
this is neither necessary nor sufficient for 91.171).
Anyone have thoughts on this or know a FSDO that thinks differently?
John
om...
Old September 21st 03, 07:00 AM
Stan Gosnell
"John Harper" wrote in
news:1064079581.743889@sj-nntpcache-5:
signal on the ground at an airport (without a designated
checkpoint) - which I do at my home airport - then a simple
Yep. We do this all the time. We have lots of helicopter
bases, not close to an airport, & the VOR's have to be checked
every 30 days, so we just tune in a VOR on both and cross-check
them. If we can't get a signal on the ground, a check in the
air will work.
Regards,
Stan
