Alternate Mimimums?
Old December 24th 03, 01:53 PM
smf
Default Alternate Mimimums?
What exactly does the /A\na on approach plates mean. I know it says
Alternate minimums not authorized. Does it mean the airport can't be used as
an alternate?
thanks
Steve
Old December 24th 03, 05:47 PM
KevinChandler
It means that this airport cannot be used as an alternate for an IFR flight
plan. It can be used as the primary destination; however, it can not be
used as an alternate. Keep in mind, alternate airports are only required in
certain weather conditions.
"smf" wrote in message
news:F_hGb.22853$HQ.7869@okepread02...
as
an alternate?
thanks
Steve
Old December 24th 03, 06:05 PM
Ron Natalie
"KevinChandler" wrote in message ...
It means it can't be the legally required alternate for filing a flight plan.
An alternate is required when any of the following is true:
1. The weather forecast for the ETA +/- hour isn't going to be 2000' and 3 miles
(1-2-3) rule.
2. The destination has no published approach.
In addition to the alternate NA restrictions, the alternate must be served
by an approach you are equipped for that does not involve GPS.
Of course, all of this only applies to the legal requirements for filing a plan
and computing the required fuel. Where you actually go if you can't get
into your destination is unaffected by what you put down as an alternate.
Old December 24th 03, 07:24 PM
Tarver Engineering
m...
flight
required in
plan.
3 miles
(1-2-3) rule.
Isn't the GPS rule only true if your primary destination used a GPS
approach?
plan
Old December 24th 03, 08:08 PM
PaulaJay1
In article , "KevinChandler"
writes:
Or if you are filing to an airport without an approach.
Chuck
Old December 24th 03, 09:16 PM
Michael
an alternate?
Not quite. It means that approach can't be used in determining
alternate minima for that airport.
There are three kinds of alternate minima (see 91.169c):
For a precision approach, 600-2 unless otherwise noted
For a non-precision approach, 800-2 unless otherwise noted
If no approach exists, weather conditions that allow descent from the
MEA, approach, and landing under basic VFR.
Under these rules, ANY airport (even one with no published approaches)
can be used as an alternate if the weather is good enough, and the
determination of how good the weather has to be (alternate minima for
the airport) is made based on what approaches are available.
The /A\na means that the specified approach is not to be used as a
factor in the determination. It doesn't mean the airport can't be
used as an alternate - other approaches at the same airport may not
have the same restriction, and in any case even if all approaches are
so restricted the airport can still be used as an alternate if the
weather is good enough.
I have actually seen one airport served by half a dozen approaches,
including an ILS, where all the approaches were noted /A\na except one
NDB approach. This means that rather than using the typical minima
for an ILS-equipped airport (600-2) the more restrictive non-precision
minima (800-2) must be used. Note that this does not preclude the use
of the ILS approach to get into the airport should you need to go
there.
Michael
Old December 24th 03, 09:47 PM
ArtP
On Wed, 24 Dec 2003 10:24:31 -0800, "Tarver Engineering"
approach?
GPS can't be used for an alternate regardless of the type of approach
at the primary.
Old December 29th 03, 03:52 PM
Michael
NDB approach.
Any idea why?
My understanding was that an approach got the /A\ thingie if the navaids
required to fly it were not monitored.
That sort of makes sense - the NDB probably had remote monitoring
because it was part of an airway once, long ago. I think the last of
the NDB airways in the US were decomissioned a couple years ago,
though.
If you look up the alternate mins for KCLL (College Station, TX) you
will see that the ILS and LOC BC go NA when the tower closes, but the
VOR approach doesn't. I suspect this is because CLL VORTAC must be
remotely monitored because it forms the basis of multiple STAR's
serving Houston and Dallas, whereas the ILS transmitter is probably
only monitored in the tower cab.
Michael
Old December 29th 03, 07:59 PM
Scott Skylane
NDB approach.
Any idea why?
though.
/snip/
Not sure about the Lower 48, but there are still plenty of Low Frequency
airways in Alaska. In fact, quite a few of our NDB's have DME
associated with them.
Anyone know of any colored airways in the ConUS?
Happy Flying!
Scott Skylane
alternate carb heat Ray Toews Home Built 16 October 29th 04 01:41 PM
Alternate turbine fuel Robert Bates Home Built 24 June 7th 04 08:16 AM
Alternate requirements Anthony Chambers Instrument Flight Rules 8 September 17th 03 10:45 PM
NA as alternate...redux Bob Gardner Instrument Flight Rules 1 September 11th 03 11:26 PM
Aircraft engine certification FAR's Corky Scott Home Built 4 July 25th 03 07:46 PM
