LAX?
Old April 17th 06, 02:56 AM posted to rec.aviation.ifr
Default LAX?
Has anyone ever flown a light single into LAX? If so, would you care to
offer some advice? In a few months, I've got a relative who is flying into
LAX from overseas, and I would much rather fly in to pick them up rather
than face the madhouse we call "driving to LAX". Do they prefer IFR or
VFR arrivals? There are two FBO's listed: Mercury and Landmark. Is one
better than the other? How about landing fees? What would they charge for
a quick in-and-out to pick someone up?
Thanks!
-- Dane
Old April 17th 06, 06:24 AM posted to rec.aviation.ifr
Default LAX?
Thanks!
-- Dane
I have no idea what the landing fees are these days. But, I do know the
only place they will allow you to park would be at one of those FBOs,
which are on the south side of Runway 25L and completely separate from
the air carrier passenger terminals.
It would require public ground transportation via the air carrier
drive-around then down Sepulvada Blvd, east on Imperial to the FBO.
It would be easier to go into Hawthorne Airport than go through that LAX
drill. Unless you are very, very familiar with Hawthorne Airport
procedures you are well advised to arrive IFR. If the weather is good
and you get a good airspace briefing, departing VFR is somewhat easier
than arriving.
One little screw up and you have a Class B bust. IFR prevents that,
especially into Hawthorne.
Hawthorne is an easy jumb onto the 105 Freeway and only a few miles from
LAX. It would probably be easiest for your passenger to take a taxi to
Hawthorne.
Old April 17th 06, 07:33 AM posted to rec.aviation.ifr
Default LAX?
I have a freind who flew a C172 into LAX three years ago for the
purpose exactly as yours. He flew from El Monte (EMT), which is a
towered airport 20 miles east of LAX. Since EMT is a local airport,
he just needed to ask tower to request a slot for LAX before starting
the engine. Otherwise, you have to call (telephone) the tower at least
one hour before your flight in order to arrange a slot. Once take
off, ATC will ask you VFR along the I-10 freeway until 3 to 4 miles out
of Runway 24. Then they clear you into Bravo airspace and ask you
maximun forward speed to the touch down zone. That's not a problem
because Rwy24 is almost 10000 feet.
The only FBO was Garrett at that time. They will van you to the other
side of terminal and pick up the passanger and back. There was some
very high landing fee but could be waived by purchase some fuel.
The best way to pick up pessangers in LAX is to fly a helicopter, if
you can, as my the other friend does all the time. There are several
heliports on top of LAX parking structures. Best of all, they are free
(comparing to parking a car there). And you only have to talk to LAX
tower prior you cross the mid-field of RWY24, no prior arrangement is
needed.
Old April 17th 06, 10:01 AM posted to rec.aviation.ifr
Default LAX?
"Dane Spearing" wrote in message
into
for
do Hawthorne!
Old April 17th 06, 04:53 PM posted to rec.aviation.ifr
Default LAX?
Hawthorne seems quite anti-climatic.
-Robert
Old April 18th 06, 03:31 AM posted to rec.aviation.ifr
Default LAX?
In the 1960s and even into the mid-1970s those of us who were airline pilots based at LAX could fly light singles into LAX and park on our airline's maintenance ramp (not the passenger terminal ramp).
(Why) did it stop?
Jose
The price of freedom is... well... freedom.
Old April 18th 06, 04:04 AM posted to rec.aviation.ifr
Default LAX?
(Why) did it stop?
Well, this may not be the direct reason but it may indirect reason...
On August 31, 1986, a Piper Archer mid-air collided with Aeromexico
Flight 498 DC-9 in approch to LAX. 64 in DC-9, 3 in Piper and 15 on
the ground died. That event caused FAA established Class-B airspace.
This greatly reduced the small GA airplanes accessing the major
airports such as LAX.
You can read the full story at AOPA:
http://www.aopa.org/asf/asfarticles/2001/sp0101.html
Old April 18th 06, 12:35 PM posted to rec.aviation.ifr
Default LAX?
(Why) did it stop?
That is not correct. The Class B (TCA prior to airspace
reclassification to ICAO nomenclature) was established prior to the
midair to which you refer. In fact, the Piper was clipping a corner of
the Class B when the midair occurred.
An excerpt from the NTSB's probable cause:
AN INV REVEALED N4891F HAD INADVERTENTLY ENTERED THE LAX TERMINAL
CONTROL AREA (TCA) & WASN'T IN RADIO CONTACT WITH ATC.
As to airline employees flying light aircraft into LAX to park at their
respective carriers' maintenance hangars, Class B had no affect on that
at all.
