WAAS GPS approach question.
Old April 20th 06, 02:06 AM posted to rec.aviation.owning
Default WAAS GPS approach question.
Hello,
I read on the Garmin page that their 480 is Waas certified...so that
you can fly precision approaches without an ILS... what does this
mean exactly? If I'm coming into an airport with only an NDB
approach, can I use the 480's capabilites to fly a precision approach
and get down to a lower MDA/DH?
-dr
Old April 20th 06, 03:02 AM posted to rec.aviation.owning
Hello,
It means you can use the LPV minima line on a RNAV(GPS) approach chart, and
that assuming your 480 was properly installed you can follow localizer-like
and glideslope-like needle guidance on that approach.
Old April 20th 06, 03:52 AM posted to rec.aviation.owning
Can you use the 480's glideslope to guide you into a VOR approach that
is NOT GPS, but using a descent gradient that will hit the altitude at
the waypoints as charted? Same approach as flying it by hand, just a
stabilized, even descent. Hope that makes sense.
Old April 20th 06, 06:05 AM posted to rec.aviation.owning
Assuming it's a VOR(GPS) approach, and not a circle to land only, Yes. The 480 provides VNAV
guidance suitable for LNAV/VNAV or if not charted, then referred to as "advisory VNAV", but basically it
works the same - you get vertical guidance to the runway.
Old April 20th 06, 03:46 AM posted to rec.aviation.owning
"Dico" wrote in message
Hello,
If the airport has only an NDB approach, how are you going to fly a GPS
approach of any sort?
Old April 20th 06, 04:00 AM posted to rec.aviation.owning
"Matt Barrow" wrote in message
Hello,
In other words, if there isn't a published approach, you can't invent one
for your own use. It's not legal and not safe.
Old April 21st 06, 02:53 AM posted to rec.aviation.owning
I thought the FAA approved the use of GPS for any NDB waypoint. A plane
without ADF can fly any ADF approach with a IFR approach certified GPS. GPS
waypoints can also be used in lue of ADF for missed approach holds, so you
can fly any approach that has "ADF required" without an ADF if you have an
IFR certified GPS.
Hello,
Old April 21st 06, 01:33 PM posted to rec.aviation.owning
They did. But note the word "waypoint"
A plane
IFR certified GPS.
Note this from the AIM: (emphasis mine)
"(6) Charted requirements for ADF and/or DME can be met using the GPS
system, **EXCEPT** for use as the principal instrument approach navigation
source."
This would be true for a stand alone NDB approach (i.e. with no GPS
overlay); and for the primary DME approach at Martin State (near BWI).
If there is a published GPS overlay, that would be different. But not all
NDB approaches have GPS overlays.
Old April 20th 06, 06:31 AM posted to rec.aviation.owning
-dr
No.
But if you have an RNAV approach with precision/vertical guidance
component, (and I am presuming the approach lighting is up to snuff
before that type of approach chart is issued).. then you could use the
480 box to execute that approach without any ground based navaid guidance.
Dave
Old April 20th 06, 11:24 PM posted to rec.aviation.owning
WAAS Approaches have vertical guidance but they
are not classified as "Precision"
Bill Hale
GPS approach question Matt Whiting Instrument Flight Rules 30 August 29th 08 03:54 AM
GPS missed approach question xyzzy Instrument Flight Rules 15 September 15th 05 02:24 AM
Approaches and takeoff mins. jamin3508 Instrument Flight Rules 22 September 14th 05 02:51 AM
Contact approach question Paul Tomblin Instrument Flight Rules 114 January 31st 05 06:40 PM
Where is the FAF on the GPS 23 approach to KUCP? Richard Kaplan Instrument Flight Rules 36 April 16th 04 12:41 PM
