NDB or GPS Rwy 33 EPM
Old May 19th 04, 08:07 PM
Steven P. McNicoll
Default NDB or GPS Rwy 33 EPM
"Ron Rosenfeld" wrote in message
This approach is marked radar required, and there is no charted feeder
route to the IAF. So one approaches via a random route under radar.
ATC will not issue an approach clearance until within 15 miles of
the NDB. In the past I was told this was due to their need to
ensure the a/c was within the service volume for the facility.
However, if the a/c is using GPS and executing the GPS Rwy
33 approach, what is the point of delaying clearance issuance
until 15 miles out?
None. Nor is there any point in delaying clearance issuance if the aircraft
is using the NDB, as ATC is providing radar monitoring.
Old May 20th 04, 03:03 AM
Ron Rosenfeld
On Wed, 19 May 2004 19:07:49 GMT, "Steven P. McNicoll"
One reason for delaying the clearance when using the NDB might be that,
although ATC may be radar monitoring, once one descends below 4000', there
is no direct radio contact with ATC.
Old May 20th 04, 03:38 AM
Steven P. McNicoll
be that, although ATC may be radar monitoring, once one
descends below 4000', there is no direct radio contact with ATC.
Radar monitoring is required even if the aircraft is executing the GPS RWY
33 approach.
Old May 20th 04, 04:01 AM
Ron Rosenfeld
On Thu, 20 May 2004 02:38:59 GMT, "Steven P. McNicoll"
33 approach.
Why do you think this delay in issuing the clearance is a policy at the
Boston ARTCC?
If it is not justified by the FAA published procedures, do you have a cite
from the manual that I could present to the supervisor at the Boston ARTCC
to support its elimination?
