oil blow out IO-360
I have an IO-360-A3B6 900 SFNEW in '97. I used to be able to keep about
7 quarts in it without it blowing out. Now it seems to be blowing oil down to about 5.5 quarts. Since I live in the 100F OATs part of the country, the extra oil really helps cooling. Should I worry about what is causing the extra oil blow out or just chock it up to an aging engine. I know some engines always blow out to 6ish quarts. If I shouldn't worry about the extra blow out I'll just put a separator on it, but I don't want to mask a problem first. One recent change is we raised the oil pressure since the regulator had been slipping prior to annual. -Robert |
Similar Threads | ||||
oil blow out IO-360 | Robert M. Gary | Piloting | 18 | July 17th 06 04:44 PM |
Blow out static port | [email protected] | Owning | 36 | May 13th 05 02:59 PM |
Aviation song for US? | Jürgen Exner | Piloting | 39 | March 7th 05 02:01 AM |
Cambridge Fuse Question | Brian Iten | Soaring | 9 | January 4th 05 02:43 PM |
Boxer to blow billions on MANPADS | Henry J. Cobb | Military Aviation | 0 | December 3rd 03 04:44 PM |
