I am using 3.5" dia Aeroduct-CAT ducting for a short distance directly
from my intake plenum under my fuselage to the carburetor. The problem with the CAT is that the wire reinforcing and fabric do not give radially well, so it transmits some engine vibration to the fuselage. I would like to find some very flexible ducting (3.5 " bore). I noticed some of the production built flexible rubber ducting in my car from air filter to the fuel control(?). I was looking at my 2.5" rubber hose that ducts the exhaust fumes out of the garage but it is really bulky and not easy to apply a clamp to. Anybody has specific product and sources suggestions? |
Thanks, but that stuff is only flexible for shaping and not rotational
vibration. Most of those "flexible" ducts have wire reinforcing helix which resists rotational motion along the axis of the duct. Morgans wrote: Look in the home improvement area of a big box hardware and lumber store. Flexible clothes dryer duct is available in a aluminized plastic that is rated for the heat of a gas dryer outlet, so it should stand up to the environment, if it does not get too too hot. -- Jim in NC |
"abripl" wrote in message oups.com... I am using 3.5" dia Aeroduct-CAT ducting for a short distance directly from my intake plenum under my fuselage to the carburetor. The problem with the CAT is that the wire reinforcing and fabric do not give radially well, so it transmits some engine vibration to the fuselage. I would like to find some very flexible ducting (3.5 " bore). I noticed some of the production built flexible rubber ducting in my car from air filter to the fuel control(?). I was looking at my 2.5" rubber hose that ducts the exhaust fumes out of the garage but it is really bulky and not easy to apply a clamp to. Look in the home improvement area of a big box hardware and lumber store. Flexible clothes dryer duct is available in a aluminized plastic that is rated for the heat of a gas dryer outlet, so it should stand up to the environment, if it does not get too too hot. -- Jim in NC |
"abripl" wrote in message oups.com... Thanks, but that stuff is only flexible for shaping and not rotational vibration. Most of those "flexible" ducts have wire reinforcing helix which resists rotational motion along the axis of the duct. I must not fully understand how it is going to be used. How many degrees of rotation are you thinking it will have to put up with? -- Jim in NC |
Take a garden hose and put it between your two hands in a straight
line. If you just bend the center line it it will give easy. But if you try keep the center line straight and rotate one hand one way and the other other way it will resist. A very soft rubber hose might give in such rotation but not a stiff one. In the same way most of the "flexible" ducts do not really give in such "shear" rotation and are "stiff" - especially if they have a wire helix coil inside. My engine setup is exactly such that the yield needed is in "shear" along the center line for a short piece of ducting. Morgans wrote: I must not fully understand how it is going to be used. How many degrees of rotation are you thinking it will have to put up with? -- Jim in NC |
"abripl" wrote My engine setup is exactly such that the yield needed is in "shear" along the center line for a short piece of ducting. I don't understand how you would develop any rotation, except for the flexibility than your rubber engine mounts. how many degrees of rotation is needed? -- Jim in NC |
Morgans wrote: "abripl" wrote I don't understand how you would develop any rotation, except for the flexibility than your rubber engine mounts. Yes. But thats enough to transmitt vibration. If you noticed, many car manufacturers use flexible rubber intake hose from air cleaner to to the fuel control unit. how many degrees of rotation is needed? The one I described to start with. -- Jim in NC |
"abripl" wrote in message oups.com... I am using 3.5" dia Aeroduct-CAT ducting for a short distance directly from my intake plenum under my fuselage to the carburetor. The problem with the CAT is that the wire reinforcing and fabric do not give radially well, so it transmits some engine vibration to the fuselage. I would like to find some very flexible ducting (3.5 " bore). I noticed some of the production built flexible rubber ducting in my car from air filter to the fuel control(?). I was looking at my 2.5" rubber hose that ducts the exhaust fumes out of the garage but it is really bulky and not easy to apply a clamp to. Anybody has specific product and sources suggestions? Sounds like a job for silicone, do a google search using "3.5 inch silicone hose". http://froogle.google.com/froogle?q=...oogle&ct=title |
oups.com... I am using 3.5" dia Aeroduct-CAT ducting for a short distance directly from my intake plenum under my fuselage to the carburetor. The problem with the CAT is that the wire reinforcing and fabric do not give radially well, so it transmits some engine vibration to the fuselage. I would like to find some very flexible ducting (3.5 " bore). I noticed some of the production built flexible rubber ducting in my car from air filter to the fuel control(?). I was looking at my 2.5" rubber hose that ducts the exhaust fumes out of the garage but it is really bulky and not easy to apply a clamp to. Anybody has specific product and sources suggestions? One could, of course, construct one's own duct, eh? Silicon caulk, fiberglass cloth, make a form and you are good to go. Note: you said "short distance" - for "long" distances, without some form of reinforcement the duct could collaps from the pressure difference (I've seen it happen). You could use loops of wire in place of teh continuous coil. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
| Thread Tools | |
| Display Modes | |
| Q. about Eurofighter intake | Alistair Gunn | Military Aviation | 1 | August 20th 04 07:58 AM |
| Lycoming intake preheater | Dale Larsen | Home Built | 5 | June 6th 04 11:32 PM |
| Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 07:42 PM |
| high-speed camera view of a piston intake, combustion, exhaust | R.Hubbell | General Aviation | 0 | February 20th 04 04:36 AM |
| flexible wing human powered flight | patrick timony | Home Built | 3 | January 15th 04 01:21 AM |
