Why don't voice radio communications use FM?
Old September 2nd 06, 02:40 PM posted to rec.aviation.piloting
Mxsmanic
Default Why don't voice radio communications use FM?
Perhaps this is a naive question, but: Why don't voice radio
communications for aviation use FM radio instead of AM radio? I
realize there's substantial inertia in the installed base of AM
equipment, but surely one could allocate some new frequencies to FM
and use them in parallel for some years to ease the transition.
The reason I ask is that improper and misunderstood radio
communication is a leading cause of accidents, and so it seems that
anything that can make that communication clearer would greatly
improve safety. I can barely understand what I hear on the radio. It
is true that the communication is very standardized, making it easier
to guess what is being said, but the results are pretty unpleasant if
one guesses wrong.
On a related note, it has occurred to me that one could develop
voice-recognition systems that understand the speech of a pilot and
then repronounce what he says in an extremely standard synthetic
voice. This could also improve understanding, especially for
non-Anglophone pilots who speak with heavy accents. The same systems
could clean up the speech so that it is absolutely standard, with no
missing or added words. Of course, the issue here is that the system
would be stuck if it cannot recognize what is being said, or if a
completely non-standard utterance is made by the pilot. A natural
extension of this would be systems that recognize standard phrases in
one language and translate them to another, but that would be even
more dangerous if the system ever failed.
Still another idea is special training systems that listen to a
pilot's speech and transcribe it, and point out any problems with
understandability. Again, this would be most useful for
non-Anglophone pilots, but it would work for anyone. If a machine can
understand a pilot's speech clearly, then a human being should
certainly be able to understand it that much more easily.
Old September 2nd 06, 02:43 PM posted to rec.aviation.piloting
Steven P. McNicoll[_1_]
"Mxsmanic" wrote in message
news
Wouldn't that reduce the available frequencies?
Old September 2nd 06, 03:12 PM posted to rec.aviation.piloting
Peter R.
A leading cause of accidents? Where did you get this statistic?
one guesses wrong.
Guess? If a pilot or controller is not able to comprehend the other side's
transmission, there is no guess. "Say again?" is the phrase of choice and
it is used all over the frequencies.
Peter
Old September 2nd 06, 03:13 PM posted to rec.aviation.piloting
James Robinson
I understand it is because of a characteristic of FM called "capture
effect" that blanks out weaker transmissions when two radios transmit at
the same time. The listener would have no idea that a second, weaker
transmission was being made.
With AM, when two radios transmit on close frequencies, you either hear
both signals poorly, or you get squeal, which is the sum of the two
signals. This characteristic is considered important when you have elevated
transmitters that can be hundreds of miles away, like on aircraft.
Old September 2nd 06, 03:38 PM posted to rec.aviation.piloting
Larry Dighera
On Sat, 02 Sep 2006 14:40:40 +0200, Mxsmanic
wrote in :
I presume the reason stems from AM radio's introduction into aviation
after CW was used prior to and during WW-I. The cost of re-equipping
all aircraft with new radios is also not insignificant.
I realize there's substantial inertia in the installed base of AM
AM frequencies are currently 25 kHz wide. FM would require more
bandwidth. Regardless, where would you place these newly allocated
frequencies?
What is the source of that questionable statistic?
and so it seems that anything that can make that communication clearer
would greatly improve safety.
Hence the popularity of Active Noise Reduction headsets.
Do you use an ANR headset?
It is true that the communication is very standardized, making it easier
one guesses wrong.
Request 'say again' if in doubt.
voice.
What would you estimate the cost of re-equipping all aircraft with
such a system might be?
Pilot: "Oh ****!"
Electronically rephrased: "Mayday!"
I can understand you frustration with non-standard phraseology and
foreign accents, but given the current state of the art, such a voice
recognition/synthetic voice system as you suggest would probably be
unworkable not to mention costly and short lived. I would expect to
see data-link equipment (ACARS* or more likely ATN** or NEXCOM***)
available for GA aircraft soon.
* http://en.wikipedia.org/wiki/ACARS
** http://www.tc.faa.gov/act300/act350/
*** http://www.faa.gov/nextgen/nexcom/Publib/aboutnc2.htm
Old September 2nd 06, 03:52 PM posted to rec.aviation.piloting
Emily[_1_]
Really? Can you cite some statistics? I'd be very interested in
reading them.
Old September 2nd 06, 06:00 PM posted to rec.aviation.piloting
RST Engineering
Yeah, Steve, it would. But I think we might be able to swap (on a long term
swap basis) the VHF com band for stuff up between 600 and 900 MHz. that have
very limited usage. Not only could we get way more bandwidth, but the
antenna size is cut by a factor of 6 or so.
nk.net...
news
Old September 2nd 06, 06:02 PM posted to rec.aviation.piloting
John Gaquin
....that improper and misunderstood radio
Cite, please.
... I can barely understand what I hear on the radio.
I suspect the reasons for this relate more to the environmental effects and
quality of the speakers, etc., than to the nature of AM transmissions.
Old September 2nd 06, 06:04 PM posted to rec.aviation.piloting
John Gaquin
"James Robinson" wrote in message
elevated
Sounds plausible. Marine radios also operate in the VHF band, but are FM.
They are also almost always at or very close to sea level.
Old September 2nd 06, 06:05 PM posted to rec.aviation.piloting
RST Engineering
Red herring, again. AM radio does the same suppression effect if the
signals are widely differing in power (google "AGC" or "AVC" for an
explanation). The odds of two signals being absolutely equal in time is
close to zero. True, they can start simultaneously, but the ending time is
generally measured in multiseconds. One side or the other always gets the
tag end of one conversation or the other and can figure out that a second
station is trying to get a message across.
The squeal when two nearly equal power signals is not the sum of the
frequencies, it is the difference.
elevated
UAV's and TFR's along the Mexico boarder John Doe Piloting 145 March 31st 06 07:58 PM
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 05:40 AM
terminology questions: turtledeck? cantilever wing? Ric Home Built 2 September 13th 05 10:39 PM
I Hate Radios Ron Wanttaja Home Built 9 June 6th 05 06:39 PM
AirCraft Radio Communications [email protected] Rotorcraft 0 November 13th 03 01:48 AM
