Latitude Longitude entry
Old September 3rd 06, 11:14 PM posted to rec.aviation.piloting
Chris W
Default Latitude Longitude entry
This is off topic but something that I think pilots can appreciate.
I am working on a web site that will require the entry of latitude
longitude coordinates. As you probably know there area lot of
different ways to format latitude and longitude. I have done my best to
make my code work no mater what format you use. If you have some time
and would like to try it, I want to know if anyone can break it. If you
do, please send me the data you used to break it, so I can figure out
why it broke and fix it. Below is the URL for the test. The web site
it is currently on is not the web site it is for, that is just where I
am doing the testing until I get a server set up for the new site.
http://www.thewishzone.com/LatLonTest.php
P.S. If anyone wants a copy of the code I wrote to do this, let me know
and I will email it to you.
Chris W
KE5GIX
Gift Giving Made Easy
Get the gifts you want &
give the gifts they want
One stop wish list for any gift,
from anywhere, for any occasion!
http://thewishzone.com
Old September 5th 06, 02:13 AM posted to rec.aviation.piloting
J. Severyn
Great Job Chris.
The is one of my pet peeves. Different maps, different users, etc do not
use consistent formats. My GPS will accept input in different formats, but
many times I've entered coordinates in one format when the GPS was set for
entry in a different format. I'm always pulling coordinates from topo maps
or other sources and I must not forget to do the conversion to make the
entries consistent. (or keep flipping the GPS to accept the different
formats)
The only comment I might make: It might be useful to catch a case of
mistaken mixed entry such as: 30.3 45 56 which results in a value
greater than 31 degrees. This would catch the improper entry before the
data is used, as once it is converted, might make finding the error
difficult.
Sure, I'd like to see the code if possible.
Remove the ".cutout" for my true email address.
Regards,
John Severyn
@KLVK
"Chris W" wrote in message
news:HAHKg.9416$JR5.1674@dukeread11...
longitude coordinates. As you probably know there area lot of different
ways to format latitude and longitude. I have done my best to make my
code work no mater what format you use. If you have some time and would
like to try it, I want to know if anyone can break it. If you do, please
send me the data you used to break it, so I can figure out why it broke
and fix it. Below is the URL for the test. The web site it is currently
on is not the web site it is for, that is just where I am doing the
Chris W
KE5GIX
Old September 5th 06, 03:06 AM posted to rec.aviation.piloting
J. Severyn wrote:
Great Job Chris.
formats)
difficult.
Regards,
John Severyn
@KLVK
Su- I had a bit of trouble with this recently figuring out
what google earth would accept.
http://www.multimap.com/map/
browse.cgi?lat=51.4829&lon=-0.1009
&scale=10000&icon=x
lat=51.4829 lon=-0.1009 BAD
51.4829 -0.1009 OK
51.4829 N 0.1009 W OK
51:28:58N 0:06:03W OK
Lat: 51:28:58N (51.4829) Lon: 0:06:03W (-0.1009) OK WOW!!!
Lat: 51:28:58N Lon: 0:06:03W OK
40° 4'50.36"N 96° 9'40.26"W
N/W disappeared from input boxes on processing
OK though. Google Earth.
This looks pretty nice, just tried a few and they almost all worked.
Old September 6th 06, 09:57 PM posted to rec.aviation.piloting
Grumman-581[_3_]
If you have some time and would like to try it, I want
to know if anyone can break it. If you do, please send
n234521.123
w954521.123
using the ddmmss.sss format for the longitude, it chokes on two digit
longitudes... It does work if you put a leading zero on the longitude or if
it is a 3-digit one...
Same thing happens with longitudes of the format ddmm.mmm instead of using
ddd.mm.mmm...
Old September 8th 06, 06:09 AM posted to rec.aviation.piloting
Chris W
n234521.123
w954521.123
Well let's think about this.
What if it is 5degrees do you want to do it like this..... dmm.mmmmm?
How do could the system possibly distinguish that from ddd.ddddd?
Obviously it can not. Then what about say 1 degree 3 minutes dm.mmmm?
Just move evidence of why that can't be done. If you want a format with
out any kind of separator between the degrees minutes and seconds all
fields have to be of fixed width and since longitude goes from -180 to +
180 you need to have it be dddmmss.sss or dddmmm.mmmm And since
Latitude is -90 to +90 ddmmss.ss or ddmm.mmmm is the only way to go. It
is my understanding the ddmmss.ss or ddmm.mmmmm for Latitude and
dddmmss.ss or dddmm.mmmm for longitude are standard formats in the GIS
software industry. However I would think since the web site this code
is for is not targeted at GIS professionals, most users will have
something separating the degrees minutes and seconds like dd mm ss.ss
Chris W
KE5GIX
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 05:40 AM
Nearly had my life terminated today Michelle P Piloting 11 September 3rd 05 03:37 AM
On the lighter side Soar Stanton MN Soaring 0 April 20th 05 01:52 AM
Displaced AFSS "controllers" heading for BIL and GRB Chip Jones Instrument Flight Rules 12 April 10th 05 10:22 PM
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 06:14 AM
