Why are center tanks not used?
Old September 20th 06, 02:56 PM posted to rec.aviation.piloting
tom418[_1_]
Default Why are center tanks not used?
When you say "filled" do you mean amount of fuel in the each tank compared
to each tank's capacity?
On a B727, there is a limitation which calls for tanks 1 and 3 to contain no
more than 2000 lbs than tank 2 (the center tank), prior to takeoff. So, if
you fill tanks 1 and 3 (about 12,000 lbs) you would have at least 10,000 lbs
in tank 2 (capacity of about 30,000 lbs.) to comply with this limitation.-
Tank 2 would be "partially filled" compared to its capacity, but hardly
"empty".
"Mxsmanic" wrote in message
Why does it seem that wing tanks are filled in commercial airliners in
preference to center tanks? What is the advantage to filling the wing
tanks while keeping the center tank empty or partially filled?
Wouldn't heavy wing tanks increase the inertia of the aircraft around
the roll axis?
Old September 20th 06, 05:39 PM posted to rec.aviation.piloting
Mxsmanic
tom418 writes:
I just meant that the wing tanks usually contain fuel and are filled
with equal amounts of fuel, up to and including all that is necessary
for the flight. The center tank apparently remains empty, unless its
extra capacity is needed, even to the point of not turning on the
center tank pumps (I think). And supposedly the manufacturer forbids
putting more than a small amount of fuel in the center tank (at least
in the 737) without adding at least as much to the wing tanks.
"empty".
Hmm. Sounds quite different from the 737. I wonder why.
I've always read that the 727 is a great aircraft to fly. It
certainly made history. The 737 is now doing the same.
Old September 20th 06, 07:41 PM posted to rec.aviation.piloting
karl gruber[_1_]
But that's a 727, with three fuselage mounted jet engines. It's static
loading problem is completely different than an airplane with wing mounted
engines only.
The 727 is a weird airplane, like the Falcon 50 I fly.........as far a fuel
goes.
Karl
"tom418" wrote in message
news:cUaQg.18$Rp3.10@dukeread12...
no
if
lbs
"empty".
the roll axis?
Why are center tanks not used? Bob Moore Piloting 9 September 23rd 06 07:10 PM
Exposed Electrical Wires in Boeing 737 Fuel Tanks! Larry Dighera Piloting 0 July 17th 06 07:13 PM
F-104 in Viet Nam Question Don Harstad Military Aviation 2 August 28th 04 09:40 AM
Run-in with Chicago Center Jay Honeck Piloting 93 August 24th 04 05:53 PM
Bush's Attempt to Usurp the Constitution WalterM140 Military Aviation 20 July 2nd 04 05:09 PM
