This was from another group.
At KBOI, until the current release, the approach charts showed, for the ILS10R and LOC BC 28L approaches magnetic courses of 100° and 278° respectively. The JEPP charts were changed with the current release; but the NACO charts probably still show it: http://naco.faa.gov/d-tpp/0610/00057IL10R.PDF http://naco.faa.gov/d-tpp/0610/00057LBC28L.PDF Could this have to do with the changes in magnetic variation when the charts were issued? In other words, if the charting method for a LOC course merely takes the true course, and then applies magnetic variation; and if the source showed different values for these two approaches, could that result in this apparent discrepancy? www.airnav.com does show (at least as of this morning) a two degree difference between the mag var for the airport, and that for the ILS10R approach. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Ron Rosenfeld wrote:
www.airnav.com does show (at least as of this morning) a two degree difference between the mag var for the airport, and that for the ILS10R approach. Might be magnetic variation changes (the pole does wobble around) and the approaches surveyed at different times. It's also possible that there is some ground (terrain or buildings) that causes the localizer to get bent. 2 degrees isn't much. |
![]() The ILS 10R approach was last ammended on the 159th day of 2006. The LOC BC 28L was created on the 271th day of 2006. That's less than 4 months apart. Maybe a magnetic survey was done between these two days and the LOC BC approach has the most recent variation data. Or, it's possible that the localizer signal bends slightly due to local conditions :-) Ron Natalie wrote: Ron Rosenfeld wrote: www.airnav.com does show (at least as of this morning) a two degree difference between the mag var for the airport, and that for the ILS10R approach. Might be magnetic variation changes (the pole does wobble around) and the approaches surveyed at different times. It's also possible that there is some ground (terrain or buildings) that causes the localizer to get bent. 2 degrees isn't much. |
On Thu, 28 Sep 2006 06:44:58 -0400, Ron Rosenfeld
wrote: This was from another group. At KBOI, until the current release, the approach charts showed, for the ILS10R and LOC BC 28L approaches magnetic courses of 100° and 278° respectively. The JEPP charts were changed with the current release; but the NACO charts probably still show it: http://naco.faa.gov/d-tpp/0610/00057IL10R.PDF http://naco.faa.gov/d-tpp/0610/00057LBC28L.PDF Could this have to do with the changes in magnetic variation when the charts were issued? In other words, if the charting method for a LOC course merely takes the true course, and then applies magnetic variation; and if the source showed different values for these two approaches, could that result in this apparent discrepancy? www.airnav.com does show (at least as of this morning) a two degree difference between the mag var for the airport, and that for the ILS10R approach. I notice that KBOI HI-ILS10R, which is pretty much the same as ILS10R except that it starts at FL200, has an approach course of 098 instead of 100. Both approaches use the same localizer. It must be a charting change and they haven't gotten around to redoing ILS10R yet. So much for using current charts. RK Henry |
This was from another group. At KBOI, until the current release, the approach charts showed, for the ILS10R and LOC BC 28L approaches magnetic courses of 100° and 278° respectively. The JEPP charts were changed with the current release; but the NACO charts probably still show it: http://naco.faa.gov/d-tpp/0610/00057IL10R.PDF http://naco.faa.gov/d-tpp/0610/00057LBC28L.PDF Could this have to do with the changes in magnetic variation when the charts were issued? In other words, if the charting method for a LOC course merely takes the true course, and then applies magnetic variation; and if the source showed different values for these two approaches, could that result in this apparent discrepancy? www.airnav.com does show (at least as of this morning) a two degree difference between the mag var for the airport, and that for the ILS10R approach. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) Whenever the published LOC course on a CAT II or III procedure is more than 1 degree off the actual mag course, the mag var value is supposed to be updated so that the depicted mag course is no more than a degree off. 100 course is correct because the true LOC course is 115.13 minus 15 E variation = 100.13. (If you want more information than you ever wanted about LOC values at BOI, go to this link; http://avnwww.jccbi.gov/pls/datashee...LOC&v_format=F This 1 degree tolerance doesn't apply to CAT I procedures (3 degrees is OK for them), but since the MAG VAR for BOI ILS was updated from 17E to 15E, they had to amend the CAT I procedure since it's on the same form as the CAT II procedure. The problem appears to be that although they updated the mag var for BOI LOC, someone forgot that the facility is also used at the other end of the runway as a back course procedure and it appears they should have amended that procedure at the same time, or else they decided it was still in tolerance and did not need to be changed. The true back course alignment is considered to be 295.15 minus 15E = 280.15 magnetic. They're still using 295.15T minus 17 = 278.15M. ILS or LOC Rwy 10 was amended this year and the Final Approach (FAC) mag course and mag variation can be found on page 1 at the below link. http://avn.faa.gov/acifp/20050829155...EPLACEMENT.pdf The ILS Rwy 10 course is based on using 15E variation, while the Rwy 28 procedure uses 17E variation from the same facility. The actual flight path above the ground remains the same no matter what magnetic course they publish, since the LOC signal does not move. JPH |
On Thu, 28 Sep 2006 21:24:13 -0500, JPH wrote:
Ron Rosenfeld wrote: This was from another group. At KBOI, until the current release, the approach charts showed, for the ILS10R and LOC BC 28L approaches magnetic courses of 100° and 278° respectively. The JEPP charts were changed with the current release; but the NACO charts probably still show it: http://naco.faa.gov/d-tpp/0610/00057IL10R.PDF http://naco.faa.gov/d-tpp/0610/00057LBC28L.PDF Could this have to do with the changes in magnetic variation when the charts were issued? In other words, if the charting method for a LOC course merely takes the true course, and then applies magnetic variation; and if the source showed different values for these two approaches, could that result in this apparent discrepancy? www.airnav.com does show (at least as of this morning) a two degree difference between the mag var for the airport, and that for the ILS10R approach. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) Whenever the published LOC course on a CAT II or III procedure is more than 1 degree off the actual mag course, the mag var value is supposed to be updated so that the depicted mag course is no more than a degree off. 100 course is correct because the true LOC course is 115.13 minus 15 E variation = 100.13. (If you want more information than you ever wanted about LOC values at BOI, go to this link; http://avnwww.jccbi.gov/pls/datashee...LOC&v_format=F This 1 degree tolerance doesn't apply to CAT I procedures (3 degrees is OK for them), but since the MAG VAR for BOI ILS was updated from 17E to 15E, they had to amend the CAT I procedure since it's on the same form as the CAT II procedure. The problem appears to be that although they updated the mag var for BOI LOC, someone forgot that the facility is also used at the other end of the runway as a back course procedure and it appears they should have amended that procedure at the same time, or else they decided it was still in tolerance and did not need to be changed. The true back course alignment is considered to be 295.15 minus 15E = 280.15 magnetic. They're still using 295.15T minus 17 = 278.15M. ILS or LOC Rwy 10 was amended this year and the Final Approach (FAC) mag course and mag variation can be found on page 1 at the below link. http://avn.faa.gov/acifp/20050829155...EPLACEMENT.pdf The ILS Rwy 10 course is based on using 15E variation, while the Rwy 28 procedure uses 17E variation from the same facility. The actual flight path above the ground remains the same no matter what magnetic course they publish, since the LOC signal does not move. JPH Thank you for clarifying and amplifying the details of what I suspected to be the case. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Canadian PP-ASEL and US reciprocal -- currency | [email protected] | Piloting | 5 | August 25th 05 08:52 PM |
Can GPS be *too* accurate? Do I need some XTE?? | Icebound | Instrument Flight Rules | 82 | November 22nd 04 08:01 PM |
Can GPS be *too* accurate? Do I need some XTE?? | Icebound | Piloting | 80 | November 22nd 04 08:01 PM |
While we're talking about Garmin GPS | Windecks | Instrument Flight Rules | 31 | December 2nd 03 11:28 PM |
