Another SR22
Old October 26th 06, 01:17 PM posted to rec.aviation.piloting
Terry[_1_]
Default Another SR22
What's with the SR22 crashes? Another one went down Arizona yesterday.
Old October 26th 06, 01:45 PM posted to rec.aviation.piloting
Jim Macklin
Gravity.
"Terry" wrote in message
Arizona yesterday.
Old October 26th 06, 06:58 PM posted to rec.aviation.piloting
Mxsmanic
"Jim Macklin" writes:
Gravity.
I thought Cirrus aircraft were exempted from gravity.
Old October 26th 06, 02:08 PM posted to rec.aviation.piloting
Larry Dighera
On Thu, 26 Oct 2006 05:17:49 -0700, Terry wrote
in :
It looks like that slick wing doesn't like ice:
http://www.faa.gov/data_statistics/a...a/01_121LD.txt
Old October 26th 06, 02:37 PM posted to rec.aviation.piloting
Ron Lee
in :
Sounds like pilot stupidity. Wasn't he aware that the parachute
system offers to save them from doing other stupid things like flying
into icing conditions?
The parachute system absolves the pilot of being responsible and
making sound judgments about when to fly or not fly BUT they must know
when to activate the parachute.
Ron Lee
Old October 26th 06, 02:48 PM posted to rec.aviation.piloting
Larry Dighera
On Thu, 26 Oct 2006 13:37:27 GMT, (Ron Lee)
wrote in :
You sound like an expert in the subject. :-)
Old October 26th 06, 05:09 PM posted to rec.aviation.piloting
rps
in :
Why would you jump to that conclusion? Maybe he thought that he could
descend into a nearby airport. According to Flightaware, he was going
from Reno (KRNO) to Lake Tahoe (KTVL). The flight path ends near
either Carson (KCXP), which has a 5900' runway, or Minden (KMEV), which
has a 7400' runway. There are at least these other possibilities:
1) I think the Cirrus POH indicates to deploy CAPS in the event a safe
landing cannot be made. If the pilot thought that he could keep his
speed up and get into KCXP or KMEV, he may have been tempted to attempt
a landing and stalled with no chance of recovery, such as in a steep
turn. CAPS is to be used as a last resort, such as in complete IMC or
inhospitable terrain.
2) CAPS can be deployed only after getting the speed down to about 133
knots. His cruise speed would probably have been about 180 knots. If
he decided to deploy the CAPS, his wing may have stalled while he
attempted to get his airspeed down to CAPS deployment speed.
3) He may have been above Lake Tahoe, which is big, deep, and cold. If
I thought the plane is flyable, I'd probably head close to shore before
pulling the CAPS handle as I'm not sufficiently confident of my ability
to swim long distances or tread extremely cold water for an extended
period.
He may have been stupid in departing into known icing, but I didn't
check yesterday's METARs or PIREPs in the area, and so don't know
whether icing was forecast or known. However, we don't yet know why he
didn't pull the 'chute handle and so can't yet call him stupid for that.
Old October 26th 06, 05:23 PM posted to rec.aviation.piloting
rps
period.
I'll retract the third possibility as Flightaware clearly shows that he
was not over the lake.
Old October 26th 06, 05:33 PM posted to rec.aviation.piloting
BDS[_2_]
"rps" wrote in message
WAUS45 KKCI 251345 SLCZ WA 251345 AIRMET ZULU UPDT 2 FOR ICE AND FRZLVL
VALID UNTIL 252000 AIRMET ICE...ID MT WY NV UT CO AZ NM FROM GTF TO 20WNW
MLS TO AKO TO TBE TO INW TO ELY TO BOI TO GTF OCNL MOD RIME/MXD ICGICIP BTN
FRZLVL AND FL200. FRZLVLS 050-080 OVR NRN AND WRN PTNS AREA RSG TO 100-120
OVR SRN AND ERN PTS. CONDS SPRDG NEWD DURG PD...CONTG BYD 20Z THRU 02Z.
ELSW...NO SGFNT ICE EXP OUTSIDE CNVTV ACT. FRZLVL...SFC-080...N AND W OF
FMG-OAL-BCE-JAC-BOY-GGW LN  ...080-120...N AND W OF BZA-TCS-LVS-DEN-MCK LN
 ...120-140...S AND E OF BZA-TCS-LVS-DEN-MCK LN ..
WAUS45 KKCI 251945 SLCZ WA 251945 AIRMET ZULU UPDT 3 FOR ICE AND FRZLVL
VALID UNTIL 260200 AIRMET ICE...ID MT WY NV UT CO AZ NM FROM HLN TO MLS TO
CYS TO LVS TO 20W SJN TO PGS TO TWF TO HLN OCNL MOD RIME/MXD ICGICIP BTN
FRZLVL AND FL220. FRZLVLS 050-080 OVR NRN AND WRN PTNS AREA RSG TO 100-120
OVR SRN AND ERN PTNS. CONDS SPRDG NEWD DURG PD...CONTG BYD 02Z THRU 08Z.
 ...120-140...S AND E OF BZA-TCS-LVS-DEN-MCK LN ....
METAR KHND 251856Z 03011KT 10SM CLR 21/05 A3001 RMK AO2 T02110050 SLP129
METAR KIGM 251859Z AUTO 23018G21KT 10SM CLR 19/10 A2999 RMK AO2 SLP108
T01890100 TSNO
METAR KINS 251856Z AUTO 35010G15KT 10SM BKN085 18/M08 A3006 RMK AO2 SLP149
T01831083
METAR KDRA 251853Z 03013KT 10SM FEW070 SCT090 19/M11 A3006 RMK AO2 SLP150
T01891106
Old October 26th 06, 06:03 PM posted to rec.aviation.piloting
gpsman
rps wrote: brevity snip
I've never flown in icing conditions... but ISTM he'd be able to slow
his airspeed to 133kts. via the elevator and flaps... as long as the
wing was still flying, that is. The Cirrus site mentions CAPS has been
"flight tested -to- 135kts".
The POH reads: Once the decision is made to deploy CAPS, the following
actions
should be taken:
1. Airspeed.......MINIMUM POSSIBLE
The maximum demonstrated deployment speed is 133 KIAS.
Reducing airspeed allows minimum parachute loads and prevents
structural overload and possible parachute failure.
http://www.cirrusdesign.com/servicec...InfoManual.pdf
or http://tinyurl.com/sz3sj
No mention that CAPS -can't- or -won't- deploy above 133kts.
We don't yet know if he yanked the handle and it didn't deploy. Also
from the POH:
· WARNING ·
Jerking or rapidly pulling the activation T-handle will greatly
increase the pull forces required to activate the rocket. Use a firm
and steady pulling motion - a "chin-up" type pull enhances
successful activation.
Pretty tough to remember -that- as the ground is rushing toward you and
the cabin is filling with odors, I'll bet...
- gpsman
Trip report: Cirrus SR-22 demo flight Jose Piloting 13 September 22nd 06 11:08 PM
Wing Loadings (was SR22 discussion) john smith Piloting 8 June 23rd 06 11:41 PM
SR22 Spin Recovery gwengler Piloting 9 September 24th 04 07:31 AM
Cirrus SR22 Purchase advice needed. Dennis Owning 170 May 19th 04 04:44 PM
New Cirrus SR22 Lead Time Lenny Sawyer Owning 4 March 6th 04 09:22 AM
