Handheld/Panel mount radios?
Old November 4th 06, 05:59 PM posted to rec.aviation.soaring
Mike[_8_]
Default Handheld/Panel mount radios?
Are there any handheld radios that can also be conveniently panel
mounted?
I know there was once a Delcom that could, but it does not seem to be
available in the USA.
Appreciate any info.
Old November 5th 06, 08:12 PM posted to rec.aviation.soaring
Paul Remde
Hi Mike,
Not that I'm aware of. However, the Vertex Standard VXA-150 has a near
feature that may make it panel mountable. the LCD display screen in mounted
at a 45 degree angle on the top/front of the unit. It can be inverted so
you could mount the radio in a homemade tray in the panel and you would be
able to read the display from the end and slightly above the unit. You can
see details he
http://www.soarmn.com/cumulus/vertex.htm
You may also want to check out my handheld and panel mounted radio
comparisons.
http://www.soarmn.com/cumulus/radios-handheld.htm
http://www.soarmn.com/cumulus/radios-panel.htm
In the long run, a panel mounted radio will give you much better ease of use
and low maintenance which may make it less expensive in the long run.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
"Mike" wrote in message
mounted?
FOR SALE - 15 Delcom AIR960 Radios and Accessories ContestID67 Soaring 2 April 11th 06 12:31 AM
FOR SALE - 15 Delcom AIR960 Radios and Accessories ContestID67 Home Built 2 March 6th 06 06:35 PM
I Hate Radios Ron Wanttaja Home Built 9 June 6th 05 05:39 PM
TKM radios Peter Gottlieb Piloting 5 August 15th 03 02:44 PM
