MS flight simulator 2004
Old December 27th 04, 03:21 AM
Matt Whiting
Default MS flight simulator 2004
Santa delivered Flight Simulator and a Cyborg joystick this year. I
plan to use it to help maintain instrument currency when I don't have
time for the real thing. I'm finding the learning curve for FS to be a
little steep initially and it is taking a while to get things like the
joystick sensitivity set properly. It was initially WAY too pitch
sensitive compared to any 182 I've ever flown and somewhat sensitive in
roll as well. I haven't yet figured out how to control the rudder so I
can't speak to that. I don't see a joystick control for that, so it
must be on the keyboard somewhere. Also, it seemed to me that FS should
come with enroute and approach plates, however, that doesn't seem to be
the case either. It makes it hard to fly some of the canned routes with
no charts!
Can any of you who are seasoned FS users point me to a forum, newsgroup,
etc. that would be helpful to an FS newbie?
Matt
Old December 27th 04, 03:53 AM
Ben Jackson
In FS you assign a control surface to each available joystick axis (rather
than an axis to each control surface). In the axes menu you have to find
the joystick you want and set it up. The default (under the realism
settings) is auto rudder.
Ben Jackson
http://www.ben.com/
Old December 27th 04, 05:37 AM
Matt Whiting
Thanks, I found that. My joystick doesn't have a spare axis to assign
to the rudder, so I either use the keyboard or don't do slips!
Apparently, some joysticks have a twist axis for rudder assignment, but
it doesn't appear that my Cyborg has that. Just the normal X and Y axis
and the Z axis throttle lever.
Matt
Old December 27th 04, 08:49 AM
G. Sylvester
I just auto-coordinate the turns. Otherwise I lost the intended
purpose for *me* where I wanted to concentrate on my scan, setting
up and flying an approach down to minimums. To fly an approach you
don't need to do slips until the last kick out during the flare. At
that point MSFS has done its job.
Gerald
Old December 27th 04, 01:08 PM
Matt Whiting
but it doesn't appear that my Cyborg has that. Just the normal X and
Y axis and the Z axis throttle lever.
True enough. I was basically just exploring the envelope of FS. It
looks like it will be a pretty good tool for keeping basic IFR
proficiency. I still don't have the joystick adjusted to where it is
realist and lacking force feedback makes a huge difference, but at least
it will help with the scan and basic procedures.
Matt
Old December 27th 04, 02:37 PM
Gary Drescher
"Matt Whiting" wrote in message
G. Sylvester wrote:
lacking force feedback makes a huge difference, but at least it will help
Agreed. I strongly recommend a force-feedback joystick for MS Flight
Simulator. It makes trimming the plane much more realistic. Rudder pedals,
too, help make the process of flying closer to the real thing. It's
certainly possible to practice IFR procedures without that degree of
realism, but then you have to develop a different style of flying for the
sim (which is the case anyway, but to a much greater degree when you don't
have the extra equipment). I wouldn't want to acquire the habit of making
turns without rudder input.
--Gary
Old December 29th 04, 09:33 PM
Michael
It looks like it will be a pretty good tool for keeping basic IFR
proficiency.
Which it is.
I still don't have the joystick adjusted to where it is realist
And you never will. The sim is always a lot harder to fly than the
real airplane. The aero model can be tweaked for some level of realism
(meaning that the speeds/configurations/power settings you're used to
will work) but control respose will never be right. Force feedback
makes it better, but not good. Making it feel like the real airplane
is not actually impossible, but it's not something you're going to do
with the available resources.
Without the feel of the controls, scan discipline becomes dramatically
more important. You get tremendous tactile feedback through your
airplane's countrols - that's what getting used to the feel of the
airplane really means. Most people will tell you not to fly hard IFR
in an airplane until you've gotten the feel of it, and this is why.
Without that tactile feedback, you can never really tell if your
control application was of the proper magnitude for the deviation.
The lack of tactile feedback makes excellent trim essential; in
practice the trim on most sims is terrible. As a result, you are
always in a state of PIO.
For example, say you're 50 ft high. You apply just a bit of down
pressure. In the real airplane, you hold that pressure for a very long
time - because as you lose the 50 ft, your airspeed increases - which
of course causes the plane to see its trim speed by applying a nose-up
pressure to counter your nose-down pressue. In effect, as long as you
hold constant pressure, the rate of descent, after initially increasing
to the desired value, will decrease. This gives you lots of
opportunity to adjust (maybe remove entirely) the nose-down pressure.
On a sim, especially one with no (or inadequate force feedback, it
doesn't work that way. You apply pressure, and you establish a descent
rate. You think you have plenty of time to deal with this issue (based
on your real airplane experience - it's not even conscious) so you move
on to something else. By the time you come back, you're 50 ft low.
Thus the cardinal rule of sims - the less you do, the better. Shame it
doesn't work for the real airplane.
The true value of a sim is procedural. It's just like chair-flying,
only more realistic - and with the opportunity to be surprised. In
other words, it's of no particular value in practicing the physical
skills of flying, only the mental skills. Fortunately those are the
important ones. For that reason I don't recommend rudder pedals
(auto-coordinated turns are fine), fancy control yokes (joysticks are
fine), throttle quadrants or radio consoles (keyboard/screen is fine).
It's a waste of time to strive for realism, because the one place it
matters (the feel of the controls) it's effectively unattainable. The
sim is for practicing scan and navigation procedures.
Michael
Old December 27th 04, 05:19 PM
PaulaJay1
In article , "G. Sylvester"
writes:
I use FS to fly a new approach for the practice of selecting radios, setting up
the GPS, getting vector values "into the back on my brain", etc. I usually
have the autopilot fly the plane. I don't find that much value in using the
joy stick ( after all my Archer doesn't have one), rudder pedals and such.
Chuck
new theory of flight released Sept 2004 Mark Oliver Aerobatics 1 October 5th 04 10:20 PM
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Home Built 0 September 22nd 04 07:16 PM
FAA letter on flight into known icing C J Campbell Instrument Flight Rules 78 December 22nd 03 07:44 PM
Sim time loggable? [email protected] Instrument Flight Rules 12 December 6th 03 07:47 AM
