GPS approach in VFR wx at uncontrolled field
Old March 5th 07, 06:11 PM posted to rec.aviation.ifr
BobKK47
Default GPS approach in VFR wx at uncontrolled field
Is there any reason, or regulation, that states that a pilot, flying
VFR, is prohibited in flying a GPS approach to an uncontrolled field
(assuming VFR conditions at the field), or must the pilot fly the
usual pattern to land?
Thanks.
Bob
Old March 5th 07, 06:51 PM posted to rec.aviation.ifr
Dave Butler
FAR 91.113, 91.126, 91.127, and AC 90-66A seem to be the FAA's guidance
on the subject.
Old March 5th 07, 07:37 PM posted to rec.aviation.ifr
Bob Gardner
Dave has provided the regulatory info, but the bottom line is that you can
do pretty much whatever you want to do at an uncontrolled field in VFR
conditions...and sometimes people do some really weird and unexpected
things. If a pilot wants to shoot a practice instrument approach of any kind
to such an airport, the result will be a straight-in, which is covered by
the Advisory Circular he cites.
Part 91 contains all of the operational regulations you will ever need as a
Part 91 pilot. Anything that is not specifically prohibited is allowed.
Bob Gardner
"BobKK47" wrote in message
Thanks.
Bob
Old March 5th 07, 09:39 PM posted to rec.aviation.ifr
Jim Macklin
Courtesy and regulations both apply. Regulations do not
prohibit straight-in approaches, they say "if turns are
made." Courtesy says you should not fly an approach against
the traffic flow into the pattern, as well as regulations
about right of way.
Courtesy requires you announce and listen on the CTAF.
If all you want is practice, fly the approach 2 or 3,000
feet high.
Have all your lights ON.
Use two safety pilots who can see well.
"Bob Gardner" wrote in message
is that you can
field in VFR
unexpected
which is covered by
will ever need as a
| Bob Gardner
pilot, flying
uncontrolled field
pilot fly the
| Thanks.
| Bob
Old March 5th 07, 09:52 PM posted to rec.aviation.ifr
Bob Gardner
No argument, Jim, but AC 90-66A clearly shows a straight-in segment to both
single and parallel runways.
Bob Gardner
"Jim Macklin" wrote in message
about right of way.
feet high.
is that you can
field in VFR
unexpected
which is covered by
will ever need as a
| Bob Gardner
pilot, flying
uncontrolled field
pilot fly the
| Thanks.
| Bob
Old March 5th 07, 10:03 PM posted to rec.aviation.ifr
Jim Macklin
I did not mention parallel runways, but in VFR the
bottom-line is you can do almost anything as long as it is
safe and doesn't cause a collision hazard.
| Bob Gardner
| "Jim Macklin" wrote
in message
against
regulations
| about right of way.
| feet high.
line
| is that you can
uncontrolled
| field in VFR
and
| unexpected
instrument
| which is covered by
you
| will ever need as a
| | Bob Gardner
a
| pilot, flying
| uncontrolled field
| pilot fly the
| | Thanks.
| | Bob
Old March 5th 07, 10:50 PM posted to rec.aviation.ifr
Allen[_1_]
| Bob Gardner
| "Jim Macklin" wrote
in message
against
regulations
| about right of way.
| feet high.
line
| is that you can
uncontrolled
| field in VFR
and
| unexpected
instrument
| which is covered by
you
| will ever need as a
| | Bob Gardner
a
| pilot, flying
| uncontrolled field
| pilot fly the
| | Thanks.
| | Bob
I was looking at this the other day and ran across this from the AOPA
website. An airline pilot was approaching to land using a right hand turn
to final. He was far enough out that he argued he actually entered the
traffic pattern as a straight-in approach. Another aircraft in the pattern
already had to alter course to avoid the airliner.
The Alaska Airlines captain of this flight had his ATP certificate suspended
for 20 days for making a right turn onto final approach to Runway 8 at
Kotzebue. He maintained that the approach he had made qualified as a
straight-in approach. He had set up a right base for the runway and told
flight service that he intended to make a "right turn into" that runway. He
said that he was relying on instructions in the Alaska Airlines flight
operations manual, which provide that straight-in approaches at uncontrolled
airports "shall be planned so that the aircraft is aligned not less than
four nautical miles from the approach end of the runway." Actually, the
airplane was not completely aligned until it was about 3.1 miles out,
because the turn was begun earlier than anticipated in order to avoid
another aircraft in the area.
The Board held that even if this was a straight-in approach, it would still
be a violation of the regulation because the approach interfered with
another aircraft approaching the airport. The evidence showed that the
airliner conflicted with a Cessna 402, causing the Cessna to abort a
practice VOR/DME approach to the airport. It was the same aircraft that the
Boeing captain maintained he altered his course to avoid.
The Board said: "Aircraft making valid straight-in approaches at
uncontrolled airports would, nevertheless, be deemed in violation of FAR
section 91.89(a) [now 91.126 and 91.127] if they interfered with other
aircraft operating in the standard left-hand pattern."
So, while a straight-in approach to an uncontrolled airport is legal under
the FARs, the straight-in approach must be started some considerable (but
undefined) distance from the runway and the traffic pattern, and it must not
interfere with aircraft in the traffic pattern or on an instrument approach.
Old March 12th 07, 10:10 PM posted to rec.aviation.ifr
Robert M. Gary
The only part of the approach that actually happens in the traffic
pattern is the very last couple of miles. Usually you can fly the
approach and then work into the pattern with traffic. While you are
out there doing your procedure turns, etc you are not anywhere near
the traffic pattern.
-Robert, CFII
Old March 12th 07, 10:28 PM posted to rec.aviation.ifr
Mark Hansen
-Robert, CFII
.... and as was pointed out here recently, if you wish to do a straight-in
approach to landing, you must not interfere with any airplanes in the
traffic pattern. You must break-off your approach and join the traffic
pattern at the appropriate altitude, etc.
Old March 12th 07, 11:20 PM posted to rec.aviation.ifr
Steven P. McNicoll
"Mark Hansen" wrote in message
A straight-in has the right of way.
Straight-ins at uncontrolled airports? Danny Deger Piloting 188 February 21st 07 01:39 AM
Uncontrolled fun Roy Smith Piloting 7 July 19th 06 10:29 PM
Closing IFR flight plan at uncontrolled field paul kgyy Instrument Flight Rules 18 February 9th 06 02:27 PM
Uncontrolled airport departure-again... endre Instrument Flight Rules 13 March 1st 04 12:42 AM
Position and Hold at uncontrolled field dave Piloting 42 February 26th 04 01:25 AM
