MOCA and STAR
Old April 19th 07, 01:38 PM posted to rec.aviation.ifr
Larry R[_2_]
Default MOCA and STAR
Ok, I am trying to brush off some of the rust and getting some
recurrent training.
The task was to plan a flight, KLOU-KLEX-KJVY. (Louisville,KY). So, I
looked up the STAR Clegg2 ( http://204.108.4.16/d-tpp/0702/00697CLEGG.PDF),
and the charts.
Clegg2 *seems* to make the KLOU-KLEX simple- just hit IIU, out on 080
to Clegg. But when I look at the IFR Enroute, that happens to be the
V512 airway as well, which has a 10,000 MEA and a 2700 MOCA ( WHY the
10K, I can;t figure out). So, I looked up the AIM on MOCA, and it
tells me this is used for "decending for approach".
So, will I get a clearance KLOU IIU.CLEGG2 KLEX @ 3000?
Old April 19th 07, 10:02 PM posted to rec.aviation.ifr
Steven P. McNicoll
"Larry R" wrote in message
recurrent training.
and the charts.
The Clegg Two Arrival does not go over IIU VORTAC. The IIU 080 radial is
not a procedure track, the radial is used only to define CLEGG intersection.
Old April 20th 07, 01:27 PM posted to rec.aviation.ifr
Larry R[_2_]
Aha! Upon closer inspectioin you are right ! So with that, I'll just
do direct Clegg !
Thanks!
Old April 21st 07, 01:53 AM posted to rec.aviation.ifr
Andrew Sarangan
recurrent training.
looked up the STAR Clegg2 (http://204.108.4.16/d-tpp/0702/00697CLEGG.PDF),
and the charts.
STARs often have very high MEA's (and speeds) which are meant for
turbojets descending from higher altitudes. However, it is a good
question why the enroute MEA is 10k for V512. It may have something to
do with the fact that the FFT VOR is a T class. I can't imagine there
is anything taller than 3000' around there.
Getting the MOCA Dan Instrument Flight Rules 59 July 3rd 06 01:43 AM
A Run in with a Star William L.Snow, PE Piloting 60 May 11th 06 04:45 PM
MOCA and MEA over water??? Roy Smith Instrument Flight Rules 16 May 16th 05 08:13 PM
Starduster SA-900 V-Star bsquared Home Built 0 September 1st 04 03:21 AM
On-Star* JJ Sinclair Soaring 12 November 21st 03 12:34 AM
