Were radials usually long-stroke engines?
Old April 19th 07, 05:30 PM posted to rec.aviation.homebuilt
Default Were radials usually long-stroke engines?
Looking over the available illustrations on the net it appears
that the typical radial aircraft engine had a stroke longer
than the bore (undersquare). Is that right?
It would make sense for high torque at lower RPMs.
FF
Light weight low cost four stroke engines, good Rotax replacements. Jim Carriere Naval Aviation 0 July 8th 05 03:31 AM
Light weight low cost four stroke engines, good Rotax replacements. [email protected] Home Built 15 July 3rd 05 06:31 PM
Recoil starters on small 2-stroke engines [email protected] Home Built 17 February 26th 05 02:35 PM
High-Strength Aluminum Helps 2-Stroke Engines sanman Home Built 4 April 29th 04 01:32 AM
High-Strength Aluminum Helps 2-Stroke Engines sanman Rotorcraft 4 April 29th 04 01:32 AM
