Hi Gang,
In the next couple of weeks I'll be working with a fellow to finish his private in a C-170B. Does anyone have any notes, tricks, or gotchas I should know about? I have taildragger time in everything from a Quickie to a Lodestar, but haven't flown the 170 for 28 years. Al G |
"Al G" wrote in
: Hi Gang, In the next couple of weeks I'll be working with a fellow to finish his private in a C-170B. Does anyone have any notes, tricks, or gotchas I should know about? I have taildragger time in everything from a Quickie to a Lodestar, but haven't flown the 170 for 28 years. As straightforward as they come. Remember the old C 145 ices easily, of course. has the big flaps as well, but it's the same as a 172 as far as that goes. Bertie |
One of my partners in our Aztec owns a 170B, I've got a couple dozen hours
in the right seat. Spring gear, so watch that final 2-3 feet of your decent, especially if you have large tires and it hasn't been upgraded to C180 legs. Power is your friend while taxiing. Plan and anticipate. Keep your feet moving. Jim "Al G" wrote in message ... Hi Gang, In the next couple of weeks I'll be working with a fellow to finish his private in a C-170B. Does anyone have any notes, tricks, or gotchas I should know about? I have taildragger time in everything from a Quickie to a Lodestar, but haven't flown the 170 for 28 years. Al G |
"Jim Burns" wrote: One of my partners in our Aztec owns a 170B, I've got a couple dozen hours in the right seat. Spring gear, so watch that final 2-3 feet of your decent, especially if you have large tires and it hasn't been upgraded to C180 legs. Power is your friend while taxiing. Plan and anticipate. Keep your feet moving. You will want to wheel land it, slightly tail low. Some have a tendency to oil-can if you are going too fast when the tail is put on the ground. |
On Fri, 1 Jun 2007 08:36:50 -0700, "Al G"
wrote: Hi Gang, In the next couple of weeks I'll be working with a fellow to finish his private in a C-170B. Does anyone have any notes, tricks, or gotchas I should know about? I have taildragger time in everything from a Quickie to a Lodestar, but haven't flown the 170 for 28 years. Al G WIth full fuel, an C-145 powered C-170 is a two place airplane. Other than that, I can't think of anything bad to say about the 170 (owned a B model for 4 years and put 700 hours on it in that time frame). As far as the spring steel gear goes, no problem but your butt and eyeballs do have to figure out where the bottom of those tires are while landing.... 8^) Now that I think about it, the only other gotcha I'd watch for is mis-aligned main gear which could lead to twitchy handling during takeoffs and landings... (mine was way off when I bought it, but once the gear alignment was sorted out, it was a pussy cat on the ground). Bela P. Havasreti |
On Jun 1, 10:36 am, "Al G" wrote:
Hi Gang, In the next couple of weeks I'll be working with a fellow to finish his private in a C-170B. Does anyone have any notes, tricks, or gotchas I should know about? I have taildragger time in everything from a Quickie to a Lodestar, but haven't flown the 170 for 28 years. Al G Hello Al. Some pretty good suggestions here. I assume that you are not having to do basic taildragger instruction since he is "finishing" his private. The hardest thing I found was to get people to see the landing attitude for a "wheel landing"... You should have a blast. I have not flown a Cessna tailwheeler that was not just a fine good time. Robert |
![]() "Luke Skywalker" wrote in message s.com... On Jun 1, 10:36 am, "Al G" wrote: Hi Gang, In the next couple of weeks I'll be working with a fellow to finish his private in a C-170B. Does anyone have any notes, tricks, or gotchas I should know about? I have taildragger time in everything from a Quickie to a Lodestar, but haven't flown the 170 for 28 years. Al G Hello Al. Some pretty good suggestions here. I assume that you are not having to do basic taildragger instruction since he is "finishing" his private. The hardest thing I found was to get people to see the landing attitude for a "wheel landing"... You should have a blast. I have not flown a Cessna tailwheeler that was not just a fine good time. Robert I did have a blast. It is a really nice little A/c. He has redone the interior in leather, and added a new radio and transponder. The attitude was a shock. The 170 cowling is very low, and gives the impression of a nose low attitude when straight and level. Visibility is excellent. Yes, the gear is quite springy, even soft. It seems there might be even be some main wheel alignment issues occurring when up on the mains and depressing the gear. The fellow's attitude toward learning is great. He is an A & P, and a pleasure to fly with. Al G |
Autogas Tips and Tricks | Al[_2_] | Piloting | 46 | May 4th 07 11:54 AM |
MoGas Tips, Tricks, Concerns, How To | Al Gilson | Owning | 129 | May 17th 06 08:20 PM |
KX-170B vs GNS 430?? | Robert M. Gary | Piloting | 8 | January 23rd 05 10:05 PM |
Pocket PC Tips & Glide Navigator II Tips | Paul Remde | Soaring | 0 | December 14th 04 08:21 PM |
KX 170B/KX 170 | JimM | Home Built | 0 | October 29th 03 07:05 PM |
